People who have had someone re-gear your diffs...
Old 03-12-2007, 01:16 PM
mtrdrms's Avatar
Considering that I dont have the gears and the diffs were in good shape, how much should I expect to pay to have the local 4WD shop regear my diffs if I take them out and give them to the shop? Any input would be helpful because I am trying to decide whether or not to buy a set of used 4.56 diffs or have mine regeared.
Thanks
Andy
Old 03-12-2007, 01:24 PM
Justin311's Avatar
All I can tell you is VERY expensive ($1500 maybe?). Instead, I picked up my 4.88 geared diffs for under 500 bucks from a junkyard - plus you can sell your old ones for a few bucks. Unless its a size toyota didn't offer from the factory (5.10s+?) I would spend the time finding some used diffs if possible.
Old 03-12-2007, 01:26 PM
titicaca's Avatar
most people are about 200$ for labor per 3rd member plus parts.
Old 03-12-2007, 01:32 PM
mt_goat's Avatar
Just labor, if you take them off the truck? I'm thinking about $150-$200 per axle around here anyway.
I found a local guy here that installed my ARB locker and changed my gearing in the front for about $300 labor and I just drove it in to him. I was lucky to find Shane.
Old 03-12-2007, 01:56 PM
Lysmachia's Avatar
The higher the gear ratio the more important is it to have a really good installer because there is less room for error. This site is great with gear info: http://www.gearinstalls.com/
Also if you are going to be doing gearing and are ever considering a locker -now is the time to do it! (Saves time and money!)
Old 03-12-2007, 02:00 PM
KyleT's Avatar
i had mine done and they whine like crazy. just get new ones and have Zuk install them.
Old 03-12-2007, 02:07 PM
tc
tc's Avatar
x2
Also, the labor for installing new gears and installing a locker are basically the same (actually a little less because you don't have to take the old gears off the carrier) so, you can save a bunch of money doing a locker at the same time! You might have to wait and save up some more money before regearing, but it'll be worth it!
Old 03-12-2007, 02:11 PM
mtrdrms's Avatar
Originally Posted by tc
x2
GOOD CALL!
Old 03-12-2007, 02:48 PM
Elvota's Avatar
ZUK ZUK ZUK ZUK ZUK ZUK
Clicky the little guitar fellow to answer all your questions.
TheBFA
02-15-2020 06:55 AM
Dale Johnston
11
10-31-2015 10:22 PM
tylermx71
09-29-2015 08:49 PM
Rickstwowheels
09-29-2015 02:23 PM
rmill05
09-27-2015 01:43 PM
Quick Reply: People who have had someone re-gear your diffs...
