People That Have Done AFM Swap, Question ?.
Old 10-03-2009, 09:15 PM
myyota's Avatar
Its been several months since some of you have swapped the stock AFM for a larger one, those of you that have done this on a 22RE and have had this mod for a while now, what kind of improvements have you noticed, better throttle response, better gas mileage, maybe a little more power ?. Is anyone using an air filter on the AFM itself ?. Im getting ready to do this mod on my 4Runner because the hose that conects to the throttle body has a big crack in it and i already have the larger AFM, it came off of a 5M-GE engine, i also have the elbows and 3'' aluminum thin wall pipe, all i need to do is put it all together.
Old 10-03-2009, 09:36 PM
olharleyman's Avatar
I only have 330 miles on mine with a SUPRA afm and so far it has not missed a beat I did have to mount it a little different because of the K&N STYLE air filter back to the same stock area, throttle response is very snappy idle is very smooth not sure about mileage since it is a fresh rebuild but so far I have not got any issues with it and it's plug and play so that's another bonus
here's a couple pic's of how I have it set up
Old 10-03-2009, 09:49 PM
myyota's Avatar
You have your`s set up the way im going to do mine, except im using 3'' aluminum tubing and a silicone elbow from the throttle body to the AFM.
Old 10-03-2009, 09:54 PM
FOR NOW
Once I get this motor broke in and all the little quirks worked out I am going to try to build a passenger side snorkel got the idea just have to find the parts to do it.
Old 10-03-2009, 10:28 PM
BigBluePile's Avatar
I've had great success with my supra AFM. One of my favorite mods. easy, plug and play, better throttle response and it compliments my bigbore TB, and 2.5" exhaust. I've gained some power and MPG. I too am in the process of intake/battery swap into a custom airbox with fender snorkel trying to maintain 3" or more tubing. Plus, the air sensor in my old afm was going out anyways...lol!! Here's mine currently:
Old 10-04-2009, 02:25 PM
myyota's Avatar
any more info ?.
Old 10-04-2009, 03:10 PM
Junkers88's Avatar
I've got piles of miles on mine. So far so good. Better throttle response, better milage, easier to climb hills...... Good mod.
The following users liked this post:
Yiroocham (05-22-2019)
Old 10-04-2009, 03:32 PM
87turboyotals1's Avatar
anyone know if this would work on a 22RET as well ?
Old 10-04-2009, 03:35 PM
Indeed, I've notice on Interstate hills I can pull 5th no problem at 70-75mph.
Old 10-11-2009, 06:37 PM
unclejstoy's Avatar
so as long as it's off a 82 5m-ge it will plug in .......... i see that u guys are all pre 90 trucks and have been wondering since i have a 93 if it will work.
Old 10-11-2009, 06:40 PM
874runnersr5's Avatar
you guys mind posting the part number again.. i cant find it on my notes =(
Old 10-15-2009, 11:23 PM
I have a issue as of now (650 miles) with a lean condition not sure if it is because the L.C.Head with bigger valves but need to get it right any ideas? I think I need to turn the wheel but can't remember what direction richin it up anybody know?
Old 10-16-2009, 12:50 AM
limon32's Avatar
To myyota: You might consider non-metalic pipe rather than aluminium as heat transfer to your intake air is bad. Not sure it would make a huge difference, but something to think about?
Old 10-16-2009, 04:44 PM
kiyobrown's Avatar
Had mine on for at least 6 months. Never thrown a code, got better throttle response and mileage, but that has since been overtaken by my exhaust leak. I am very happy with it.
Old 10-18-2009, 09:04 AM
muddpigg's Avatar
Counter clockwise to richen, mark the wheel so you can dial it as you please and reset it back if you want.
LCE's tech page should have a write up, that's who I referenced.
Edit: turn wheel counter clockwise to richen, clockwise to lean. Just went back to LCE to double check. I had it backwards. already changed above.
Old 10-18-2009, 09:14 AM
Junkers88's Avatar
As long as you have a 22re it will work.
Old 10-18-2009, 04:44 PM
kiyobrown's Avatar
If I am reading correctly, 22250-43110. Thanks BBP!!
In 83 the part number switched to 22250-43150, I haven't looked into how much the wiring switched between the 2.
I thought I found one on Craigslist. A.Wilson 013 went down to go get it, since he called and they told him they had the air flow sensor.
He gets down there and it was carbed!!! The guy working there kept going on and on about how it has to be there its the only motor it came with. Alex couldn't convince the guy that the MAF was on the EFI. Bonehead!!
I always check craigslist, if I find any I try to post it up.
Old 10-19-2009, 02:13 PM
muddpigg's Avatar
Hey, scored the 82 AFM today, thanks for listening the part number.
Old 10-19-2009, 02:27 PM
kiyobrown's Avatar
Nice! Where'd you pick it up from? There is one in our area right now, but he opened it up and messed with the setting, not sure if he marked stock before he did it. Could be a PITA to get it back to stock.
Old 10-19-2009, 04:00 PM
muddpigg's Avatar
You talking about the guy in Renton on craigslist. I talked to him Sunday night, had just come from Auburn and didn't want to head right up that way. He said he marked it, so should be able to dial it back to stock location.
Quick Reply: People That Have Done AFM Swap, Question ?.
