Part number for 3vze "Water Temp. SW connector"
Hey all, I'm trying to find a part number. My truck is a 95 Pickup 4x4 3vze. The part I'm looking for is the electrical connector for the "Water Temperature Switch (for A/T)." Any help would be much appreciated...
Yotom
Yotom
Often the part number is stamped directly on the connector if its just the plastic connector plug you are looking for.
I don't believe that individual connectors (which are part of the "Wire, Engine" harness) are in the parts catalog. A good dealership might be able to tell you whether connectors of general form are available.
The part number for "Wire, Engine" is 82121-35271, but I don't think you can buy it. I'm pretty sure that's not what you really want.
A junkyard might be a good option.
I'd still look at the plug for a 5 digit number and then prefix it with 90980 for a part number of 90980-xxxxx. Lots of plugs are available, but this one may not be.
'91-'05 Toyota Wire Harness Repair Manual with pictures of plugs and part numbers:
http://www.ncttora.com/fsm/Toyota%20...r%20Manual.pdf
Avenged
07-09-2015 07:55 AM
22resymtomsbaddistributor, 3vze, back, block, connector, connectors, cts, electrical, locate, number, numbers, part, sw, temp, water
