Part identification -- intake boot?
Old 12-05-2005, 04:02 PM
Epic Ed's Avatar
Anyone know what this part of the intake is called (the large hose with the duct tape on it going into the throttle body)? The duct tape isn't cutting it for the long term and I need to get a new...thing-a-muh-bobby, but I don't know what to search terms to enter (online or for the dealer).
Also, any idea where to find a replacement for cheap?
Gracias,
Ed
Old 12-05-2005, 04:06 PM
bflooks's Avatar
that is just your intake hose. find a junk yard, an online junkyard, or shop around online. any toyota dealership will be able to give you the part number for it. just call and ask.
Old 12-05-2005, 04:09 PM
marko3xl3's Avatar
I would call it an Intake Duct, but your best bet is to contact NorthRidgeToyota (member, the guys with the 25% off offer) with the picture, and he will most likely be able to help you.
Old 12-05-2005, 04:37 PM
tc
tc's Avatar
Or replace the whole assembly with a K&N FIPK or similar. Not for the performance - just the availability and cleaner look (3 HP isn't worth that much $)
Old 12-05-2005, 05:32 PM
snap-on's Avatar
go whole hog and take both that busted ribed on and the replacement plastic one that K&N useses in there kit and have an AL mandral bent one of both pieces made.
Old 12-05-2005, 10:59 PM
Epic Ed's Avatar
Uh, guys, that is the K&N FIPK at the front of the intake. A little dirty, I know...
It's the hose that the FIPK joins to as you're moving toward the throttle body that is cracked and jacked. I'm hoping I can find one at a junkyard but I have had any luck yet.
Ed
Old 12-05-2005, 11:01 PM
Sponsor
Tofer's Avatar
you have the K&N but not the FIPK... just do the ISR mod...
Old 12-06-2005, 08:13 AM
Epic Ed's Avatar
No, the plastic bent arm duct behind the AFM is the other part of the FIPK. I'm certain I have the entire apparatus.
So the ISR mod replaces the housing all the way up to the throttle body? I'll have to check that out.
Ed
Old 12-06-2005, 08:25 AM
Sponsor
Tofer's Avatar
check out:
https://www.yotatech.com/forums/show...&highlight=ISR
https://www.yotatech.com/~corey/tech/blu_intake/blu.htm
Old 12-06-2005, 12:05 PM
nrgetic99's Avatar
Err.............No he actually has the FIPK.
It utilizes the factory rubber intake hose.
David
Old 12-06-2005, 12:23 PM
Astralplane's Avatar
Part # 17881-65020 Hose, Air Cleaner
Paid $60.30 + tax on 11/18/2003
When they got you they got you. Bastards!
Old 12-06-2005, 12:33 PM
Snorkeldepth's Avatar
I replaced both intake hoses. Yeah, they were expensive. I didn't know about ISR mods back then. If I have to do it again I think I'll go ISR. If you need a stock part check with TRDparts4U.com or ask Strap22. They have great prices and service.
Old 12-06-2005, 02:48 PM
Epic Ed's Avatar
Thank you! I may just splurge for the ISR mod, though.
Ed
icentropy
09-16-2020 02:47 PM
Doug4320
03-24-2018 10:11 PM
mskalmus
05-28-2017 07:51 AM
jakebarrett
07-10-2015 07:15 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: Part identification -- intake boot?
