oxygen sensor?
Check your FSM. You can test it under operation. Basically you get the engine warm, then make sure that the 02 sensor is "dithering" - moving from about .25v to .75v under normal conditions at abou 1400 rpm or so...
1 Post
Unplug the sensor (probably under the driver's seat). Resistance between the two terminals away from the mounting plug should be between 5.1 & 6.3 ohms @ 68degF. Post your results - if you need more info, I can post it, but it'll be long.
zz_denis
09-06-2015 03:43 PM
