Oxigan sensor
NGK or Denso
I bought mine off sparkplugs.com also, OEM NGK for $80. NGK or Denso for the 3.0, it has one oxygen sensor in the exhaust pipe almost directly below the drivers seat if you have the stock exhaust.
I have a 1992 4runner with the 3.0, and it was night and day difference once I replaced the O2 sensor at 125K.
you know you can type more than two words are a time right? it doesnt take up too much space or anything, its not like we are rationing words and you dont get very many. its always good to describe your situation and needs clearly that way you get the help you are looking for. dont be stingy with words. there is plenty to go around.
#25
you know you can type more than two words at a time right? They do not take up too much space or anything, it's not like we are rationing words and you dont get very many. its always good to describe your situation and needs clearly that way you get the help you are looking for. dont be stingy with words. there are plenty to go around.
zz_denis
09-06-2015 03:43 PM
