OME rear leaf spring forward bushings - sleeve?
Old 10-16-2021, 05:12 PM
kanurys's Avatar
Hello,
I'm installing my first set of Old Man Emu leaf springs, bushings, shackles, and shocks on our 1986 Pickup extra cab. I had to cut off one of the springs by chopping every bolt related to it. While doing this I damaged one of the sleeves on the forward mount of the spring while slicing the bolt. As I understand (correct me if I'm wrong) one needs to harvest the sleeves from the old springs/bushings for the front end of the rear leaf springs to work with the OME bushings.
Where can I get replacement sleeves to complete my install?
Thanks in a advance.
Old 10-17-2021, 06:27 PM
rsmdon's Avatar
I think you get new sleeves from ome.
Old 10-17-2021, 07:46 PM
kanurys's Avatar
Oh dang, I think I missed that in their fitment guide. I just ordered parts per this: https://arbusa.com/site/wp-content/u...up10202020.pdf
Section 1986-1988
I didn't see any reference to needing sleeves. The kits didn't come with sleeves.
Old 10-18-2021, 12:18 PM
kanurys's Avatar
You're right. I emailed OME and they said they'll send out a pair of spacers.
Old 08-28-2022, 08:33 AM
kanurys's Avatar
Just an update on the suspension work:
OME sent out new sleeves for free after a simple phone call and the dealer supplied some new forward bolts for a reasonable price. I guess some Tacomas use the same bolt so they stock them. Everything is installed and tested. I think I'll start a new thread regarding the performance of the setup.
The following users liked this post:
SomedayJ (08-28-2022)
se7enine
07-23-2018 05:54 AM
Operator
05-11-2016 08:56 AM
BigBlackYota
04-24-2015 06:08 AM
spriggan
03-24-2015 12:51 PM
nate9915
12-13-2010 12:43 PM
Quick Reply: OME rear leaf spring forward bushings - sleeve?
