Oil Pan removal on 2nd Gen 4WD Pickup - HOW TO
Old 07-15-2014, 03:15 PM
the171's Avatar
well, completed this job today. had to lay the sealant while the pan was in the truck due to the oil pickup issue. it would be very difficult to do this out of the truck and then attempt to bolt up the oil pickup. pretty much impossible in my case.
for me, lowering the diff, raising the engine, and disconnecting the idler arm was necessary to do the job. used a healthy amount of permatex gray, no gasket, light torque.
Old 08-04-2022, 04:18 PM
foampile's Avatar
I detached my upper oil pan after removing all the bolts and nuts -- but the steering rack is in the way of being able to get it out because of the front one of the two studs. Any idea what I need to do? Do I need to remove the steering rack?
MudnBullets
10-28-2018 07:00 PM
vasinvictor
01-20-2016 12:39 PM
Alaskan91
09-21-2015 04:39 AM
gog1968
06-22-2015 05:55 AM
Quick Reply: Oil Pan removal on 2nd Gen 4WD Pickup - HOW TO
