Oh my god I used UV die and the thing leaks from EVERYWHERE
Old 11-15-2011, 11:24 AM
  #41
MrArmyAnt's Avatar
I just removed the pickup tube and it came out fine. Is there a chemical that eats FIPG easily? And also when I put it back on what's the easiest way to reapply the FIPG?
Old 11-15-2011, 11:29 AM
  #42
SCToy's Avatar
Pickup tube does not get fipg LC engineering carries the gasket
Old 11-15-2011, 11:31 AM
  #43
MrArmyAnt's Avatar
Sorry I was unclear. I meant how do I reapply it to the oil pan.
I just ordered from LC dangit. Woohoo more money to shipping costs. I'm sure a yota dealer has one for an arm and a leg.
Old 11-15-2011, 11:47 AM
  #44
takeitoutgetitdirty's Avatar
The bolts could have washers behind them because that is where the a/c used to be hooked up. If it is the lower left on the timing chain cover. My 86 was the same way. came stock with a/c, by the time I got hold of it the a/c was long gone.
Old 11-15-2011, 12:38 PM
  #45
SCToy's Avatar
I just used permatex grey and it doesn't leak, but the dealer sells the Toyota stuff if you really want to be oem.
Old 11-15-2011, 12:52 PM
  #46
MrArmyAnt's Avatar
I bought the dealer stuff to the tune of 16 dollars. Won't be doing that again. And it was an upper left bolt. It has AC and still has it on it.
Old 11-15-2011, 02:46 PM
  #47
peow130's Avatar
You might be able to get away with not pulling the head for a little while, but in my experience, it'll just come back to bite you in the butt.
I did my tchain and guides, then 7 months later i was back, pulling the head off because i was losing almost a quart every 1,000 miles out of the front of the engine..
Haven't leaked yet, and have the peace of mind of a fresh HG.
Not only that, but it allowed me to scope out my pistons, and cylinder walls.
Also, i found a copper spacer where my head had been milled, or my block had been decked. Pretty neat discovery.
Old 11-15-2011, 03:10 PM
  #48
MrArmyAnt's Avatar
Why the hell would someone design an engine like this... For being reliable it seems incredibly stupid. What sort of order of operations should one do to put the block back together after a rebuild? Cant do the timing chain/timing without the cover off, cant do that without the head on, can't put the head on without the timing cover on... the circle continues...
Old 11-15-2011, 03:22 PM
  #49
SCToy's Avatar
No, you put the cover on, then you put the head on. Just get the bottom chain lined correctly and if the oil pump is on the cover before you out the cover on, the chain will stay in the right place if you don't mess with it. Check the link in my signature, it has some tips and tricks from many people. Everything I needed to know to do it is posted there.
Old 11-15-2011, 03:23 PM
  #50
SCToy's Avatar
Tip is to hang the chain with with some string from the hood to keep some tension on it.
Old 11-15-2011, 03:26 PM
  #51
MrArmyAnt's Avatar
Your signature appears to be blank. Hopefully doing it this way will last until winter... I'd rather just find another block to be building and drop it in come summer. Besides the head what's the difference on the 22re and 22rte again? Are the pistons a different height? I know the oil pumps are a bit different but the proper 22rte is hard to find...
Old 11-15-2011, 06:54 PM
  #52
SCToy's Avatar
My HG job build is HERE
Lots of good tips and pictures in there.
As far as the 22RTE, it's really not worth the headache. Do a 3.4L Swap if you want more power, cheaper, better reliability, better gas mileage.
Old 11-15-2011, 06:58 PM
  #53
MrArmyAnt's Avatar
I just liked the 22RTE due to its rarity in a 4Runner. It has the turbo digital dash with the boost gauge and all. I might look to a 3.4l though, but turbo it
What is the engine code for the 3.4? Weight? Isn't the ECM a pain in the butt?
Old 11-15-2011, 07:16 PM
  #54
SCToy's Avatar
5zvfe. There is a supercharger kit for it if you really want forced induction.
Old 11-15-2011, 07:20 PM
  #55
ToyoTech559's Avatar
wire wheel takes off FIPG
Old 11-16-2011, 04:41 AM
  #56
93toyrunner2's Avatar
x2 on Permatex Grey. It is working perfectly for my pan. Why pay $16+ for a Toyota logo? No, I do not want to spark up a battle on Dealer vs Permatex. Just my opinion.
Old 12-09-2011, 11:18 AM
  #57
MrArmyAnt's Avatar
So I reassembled everything. Got the turbo back from the rebuilder. Turns out the back stud for the manifold his helicoiled in and the helicoil is broken. Instead of dealing with undoing all the crap I just did I'm going to pull the motor. What motors are easy swaps? I'll be rebuilding the turbo motor with a ct 26 but more as a long time garage project. This blows. Anyone need a rebuild ct20 with a crappy manifold?
What's the transmission code for what's behind my turbo? It's an auto...
Old 09-17-2013, 01:29 PM
  #58
MrArmyAnt's Avatar
Not sure if I ever mentioned but before I took the motor out to sell it was determined it was this. Damnit.
Originally Posted by Mandy Tuning
many people overlook the distributor o-ring,yes ,it leaks a lot too and make huge mess in the front and 1st spark plug area.
Charecter1
11-06-2023 10:08 AM
Sleaker
08-26-2020 06:03 AM
Colington
03-08-2020 09:51 AM
Ladythump
22
11-09-2015 08:53 AM
Alex Bessinger
08-31-2015 09:17 AM
Quick Reply: Oh my god I used UV die and the thing leaks from EVERYWHERE
