OBA in my '95 4R. Lots of pics,
Old 09-28-2008, 07:59 PM
Matt16's Avatar
Originally Posted by Noltz
Quickly fixed with a small stick under the throttle stop (1800 RPM). I may look into designing an idle-up solenoid when the compressor is engaged.
I'm thinking about the same thing. Firewood on the accelerator it a bit hokey as a idle adjuster. In fact, I started a thread that you might be interested in.
ac idle up mechanism board air
Old 10-25-2008, 06:24 PM
bigt's Avatar
now that im switching my trial rig from a 95 with no options to a 93 with all options and a/c im turning the compressor to a OBA NOLTZ style!!!
thank you for this thread id is great inspiration!!!
why was your truck not having a/c a good things?
Old 11-05-2008, 08:26 PM
86tuning's Avatar
meh you'd just have to get it evacuated, then remove all the stuff you don't need/want from the vehicle.
All you'd need is the compressor and maybe the condendser (to intercool the air and condense the moisture out of it) the rest of the a/c system is not required for OBA.
Old 11-10-2008, 02:28 PM
Noltz's Avatar
Yep, like 86 said... if it was originally equipped with A/C I'd make it work again. Then I'd have no OBA!
Basically, I tried to do it as clean at Toyota would have. I've used it now on several occasions - it's great! For trail trucks, build a skid or use a trio of smaller tanks that can be mounted higher. Everything else is slick.
Old 11-10-2008, 02:53 PM
  #25
bigt's Avatar
dont need the a.c in my trail rig ...
i have a/c in my hilux.
i want to turn it into on board air!!
your post is very insipring
Old 11-10-2008, 02:59 PM
  #26
Junkers88's Avatar
Looks nice! Of course this is where I add you to my little black book of folks I don't talk to because they have more goodies than I do.
Lets see... *open black book, turn to page 1 under A for Air, onboard*..... Add noltz under Matt16.... *close book and glare at the computer*
Just kidding...... not, no really I'm kidding.......... nope still jealous......
Old 11-10-2008, 07:18 PM
  #27
yotasavg's Avatar
said it in my thread but this is really clean after a second look.
Old 11-10-2008, 07:53 PM
  #28
bigt's Avatar
yea im def doing this to the trail rig ive been gathering parts.. im gonna put the air tank from an old compressor in the back of the 4runner... cuz its gets wheeled... i figure if i can use the a/dc button to turn on the pump that would be ok... inline oiler and pressure switch ill need to grab... might be able to get one on a compressor form work and just take the compressor motor off.. use the dual tanks with pressure switch.
Old 09-08-2010, 12:41 PM
  #29
gibmedagold's Avatar
Doesn't it constantly run on the belt and build pressure whenever the truck is running? How do you get rid of the excess pressure?
Old 09-08-2010, 02:26 PM
  #30
Junkers88's Avatar
The AC compressor has a clutch that engages and disengages depending on the pressure.
Old 03-16-2011, 01:12 AM
  #31
Mudd Duck 1's Avatar
Subscribed, this will be good to rerfer to later
Old 04-25-2015, 06:04 PM
  #32
sphealy's Avatar
Pretty neat trick will have to add this to the 91 build.
05-20-2016 10:27 AM
o2raybid
09-04-2015 12:45 PM
94 Newbie
08-06-2015 10:33 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: OBA in my '95 4R. Lots of pics,
