O2 wire harness routing help -- 22re 4wd w56
Old 04-10-2011, 04:22 PM
gofaassttt's Avatar
I am stumped. I cannot figure out how to route the O2 sensor portion of the wire harness along the transmission. It seems too long. I have all the other harness connections routed and hooked up properly along the transmission. I just cannot figure out the O2 sensor routing.
I searched but cannot find a solution.
If you have pictures of the underside of your vehicle which shows how the O2 sensor harness is routed, please post as I greatly need your help. Also if you can provide pointers please post too.
Thanks
Old 04-10-2011, 08:03 PM
gofaassttt's Avatar
Found a picture and solved my problem. The harness goes along the cross member to the driver's side where it mates up with the O2 sensor connector. Unfortunately my clips are broken. Will order from Toyota.
MO transplant
04-23-2023 11:58 AM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: O2 wire harness routing help -- 22re 4wd w56
