o2 sensor location
Old 07-23-2011, 03:16 PM
my 75 toyota's Avatar
Unhappy o2 sensor location
On a 1988 pickup with a 22re where does the o2 sensor mount. The engine was replaced before i got it and no o2 sensor. On top of the exhaust manifold i have 2 football shaped plates directly off the head about 1 an 1/2 inches. I think that was for a air pump line or something . See no other places on manifold or pipe to cat. Thanks
Old 07-23-2011, 03:17 PM
Oh yeah i can be emailed at amd4me@suddenlink.net thanks again
Old 07-23-2011, 03:33 PM
xxxtreme22r's Avatar
it's typically on the exhaust manifold.
Old 07-23-2011, 03:41 PM
toyota4x4907's Avatar
'88 22res will have the o2 sensor downstream, under the cab, about a foot or two from the cat. '87 and earlier 22res have them in the manifold.
Old 07-23-2011, 03:58 PM
toyota4x4907 are they the same manifold just with the sensor bung capped off?
Old 07-23-2011, 05:03 PM
Might be '86 and earlier with the o2 in the mani, dont remember exactly.
Yes, they are the same manifolds. The bung is cast in the manifold, just not drilled for it.
Old 07-24-2011, 10:02 AM
no o2 oh what to do
Ok so my manifold does not have that bung hole in it.
Old 07-24-2011, 10:04 AM
above is pic
this is my manifold my engine is a 88 22re the manifold maybe from a 20r 1975 mod thats what its in
Old 07-24-2011, 10:09 AM
I doubt if the manifold is from a 20r on a 88 engine, as the 20r and pre 85 22r heads and exhaust manifolds have different flanges and will not work with one another.
Pic is way to small to tell anything from it BTW.
Old 07-24-2011, 12:00 PM
o2
thats what i am trying to figure out the head has the oval cut outs on top of each port. For the secondary air. But the manifold does not just the 2 football shaped plates on top
taller1
11-13-2018 02:34 PM
4x4-runner
08-30-2015 08:55 AM
4x4-runner
08-02-2015 09:24 AM
jetspeedz
07-13-2015 09:32 PM
Quick Reply: o2 sensor location
