O2 sensor location 22re
Old 12-18-2007, 09:09 PM
MtnToys's Avatar
I am swapping a 91 22re into my 85 4runner (previously had a 22re). My 4runner originally had the o2 sensor located on the exhaust manifold. I’m not sure but I believe the 91 22re had the o2 sensor located on the down pipe before the cat. Are there going to be any issues if I located the o2 sensor on manifold when using the 91 22re? Thanks for any info.
Old 12-18-2007, 09:27 PM
fillsrunner4's Avatar
No it shouldnt matter
Old 12-19-2007, 05:31 PM
AndyL's Avatar
Re-use your manifold and O2 sensor (later models have a 4 wire after the cat, early models use a single wire in the manifold).
You'll have a bunch of other issues - like locations & plugs on various components watch for the differences; may be worthwhile stripping the 91 down to a longblock, then installing the intake/exhaust/accessories off the 85.
Old 12-19-2007, 06:22 PM
Targetnut's Avatar
Unless you have the harness and ECM from the 91, you'll have to swap over everything and treat it as a long block swap. You may have an issue with the exhaust manifold stud positions on the later cylinder head that may require modification to your exhaust manifold to bolt it up.
Old 12-19-2007, 06:25 PM
misterzee's Avatar
JUST use the longblock from your newer engine. Period.
Old 12-21-2007, 09:10 PM
MtnToys's Avatar
I have all of the wiring and computer from the 91. I think I’ll stick with the 85 EFI to keep it simple.
taller1
11-13-2018 02:34 PM
montanatruck
02-26-2017 07:07 AM
Huntingtruckcletus
07-08-2015 05:26 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: O2 sensor location 22re
