O2 sensor grommet
Old 05-01-2012, 02:42 AM
LADave's Avatar
O2 sensor grommet
On an '88 SR5 4x4 with 22RE I have just replaced the O2 sensor with a Denso unit that I bought on eBay instead of from Toyota. It came without a grommet for the gaping hole under the driver's seat. Is there a preferred way to plug that before fording rivers, or splashing through puddles anyhow?
Old 05-01-2012, 08:23 AM
snobdds's Avatar
O2 sensors, even dealer supplied ones, do not come with that grommet. You will need to order a new one from the dealer.
Old 05-01-2012, 08:38 AM
LADave's Avatar
I have the old grommet in decent condition still on the old sensor wires. I could easily snip the wires and take it off, but then forcing the new connector through the grommet's aperture would be like a gerbil giving birth to a hippopotamus.
I was thinking of resorting to a gob of silicone sealer unless someone comes up with a better way.
Old 05-01-2012, 09:04 AM
xylicon's Avatar
When I bought my 02 sensor from Toyota is came with a new grommet ready to go...
Old 05-01-2012, 09:23 AM
snobdds's Avatar
Later models have the connection that does not go through the floor board. So I guess it depends on what year you have...
Old 05-01-2012, 05:23 PM
LADave's Avatar
Finally figured it out. You can unclip each terminal pin from the connector body with a probe-type tool. Then pass just the four wires through the center of the old grommet and reassemble the connector.
Obviously you need to keep careful track of which individual wire goes where.
moparbay
03-10-2023 03:50 PM
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: O2 sensor grommet
