o2 sensor / Cat question
Old 06-20-2008, 07:14 AM
wardriver's Avatar
I tested the voltage on my o2 sensors - defiantly running rich. I"m going to swap out both sensors and the cat. BTW - I cleaned out the EGR modulator filter and I think I can notice a difference in the throttle response. It was a freebie fix maybe some of you guys should try it. The how to is easy - pull the vacuum lines and pop the top cover off. Blow it out with compressed air.
This guy (Francisco@performancepeddler.com) got me a Magnaflow bolt on cat for $71.79 shipped. Thats about $20-$40 less before shipping than most other companies.
I have yet to hear of complaints on Bosch o2 sensors - IF they are the OEM replacements. I've heard plenty of issues with all brands of those universal sensors.
Rock Auto had an OEM replacement for the California emissions (upstream) for under $90 shipped. AutoZone wanted $200 for the same part number. We'll see how they work.
Old 10-26-2014, 12:45 PM
LADave's Avatar
As O2 sensor wear, they get less responsive. This causes rich-lean-rich... cycling to slow down. They also report a leaner mixture than you actually have, so the computer makes the mixture richer to compensate. When this reaches a certain point, fuel trim exceeds a preset limit, sets a code and turns on the CEL.
Old 10-26-2014, 01:41 PM
Odin's Avatar
Hmm, I keep reading about people saying to get the original Denso sensor in this application. I have no experience with it though.
tj884Rdlx
08-28-2015 12:04 PM
anniesball
07-30-2015 12:14 PM
nonstop
07-24-2015 06:29 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: o2 sensor / Cat question
