O/D and Check engine light flashing...
well as the title says the over drive and check engine light are flashing. i got in my 4runner (95 4runner 3.0 auto 4x4) after practice and those two lights we flashing. so i turned the engine off and popped the hood everything seems to be fine. my house is a couple of miles away so i just drive it. drives fine except has kinda a lag in the throttle at first then nothing is wrong. also when i floor it the over drive and check engine light would go off. anyone have any idea whats going on? all suggestions are appreciated inlcuding how to turn these lights off.
well i leave overdrive on around town but when i push it to turn it off it just lights up like normal telling me it is off but as soon as i turn it back on it will flash again im giong outside to pull the efi fuse and let it sit and think about what it did for a minute
well i went back out and put the fuse back in and reconnected the battery and got the same thing. the worst part is it wont let me check the codes (connect e1 to te1) because it just stays there blinking... i need some help on this one guys
O/D Off light blinking
Well, let me tell you my story on this. I got my transmission rebuilt, and the O/D Off light started blinking. I looked all over the internet, and got info basically telling me that a solenoid was malfunctioning. So back to the shop I went...and he told me that it wasn't covered in the warranty, and it'd be about $300 for a new one!
I did a little poking around on the truck, because according to the info I was getting, my truck (a 1994 'Yota 4X4) shouldn't be shifting into O/D at all, and it was. What I found was silly - a plug, on the passenger side of the transmission, near the shift linkage, was barely pushed up on the socket. I ran back into my shop and got a zip tie, and secured the plug in the socket.
When I drove it, and still to this day, I have had no O/D Off light.
Here's another goof - my transmission mechanic (well, my EX-mechanic, that is!) forgot to put two bolts back on the bell housing when he did the overhaul. How messed up is that!!!
Later people, hope this tidbit helps!
Shane
'94 'Yota 4X4
22RE
auto tranny
ROLL TIDE
Shane
'94 'Yota 4X4
22RE
auto tranny
ROLL TIDE
thinking maybe a solenoid problem but not sure yet.
The SAME problem? Same as what? A good description is pretty essential to get a good answer.
Here's the manual: http://web.archive.org/web/201408161...31diagnosi.pdf Read the codes, and let us know what you find. Don't forget to tell us what vehicle you're talking about (make/model/year/engine/transmission/ ....)
