Noise when throttle barely pushed!
Old 02-01-2012, 05:53 AM
the47guy's Avatar
Exclamation Noise when throttle barely pushed!
Well, this my first post(I think), been using this forum for a long time just never posted anything. I have searched for this but just am still not sure which thread suits my problem.
I currently have an 88 4runner with the 22re. I just replaced plugs, wires, oil, oil filter, fuel filter, piston rings, rod end bearings, head gasket, timing chain, sprockets, tensioner, guides(plastic), alternator, water pump, air cleaner box, all gaskets, and various vacuum lines.
I noticed that when I put my time chain on it was tight but felt it could be tighter. Seemed like it went on to easy. Very easy. Truck ran fine before so I figured it should be fine. Adjusted valves to .08 and .012 and have rechecked it After everything was together I timed it with the diagnostics jumped to 5BTDC. Took jumper out when straight to 20BTDC. She idles almost perfect. Now to my question.
When I am driving and I apply the slightest bit of throttle I get a slight metal grinding sound. Doesn't do it at idle or when you apply medium to heavy throttle. Just very light throttle. If you can hold it in that sweet spot it will keep doing it. Besides that she runs strong. Good throttle response and power. It also does it right when you let off the throttle. I can't get it to do it unless I'm actually driving so it is hard to figure out where the noise is coming from.
Any help would greatly appreciated. Thanks.
Old 02-01-2012, 06:03 AM
xxxtreme22r's Avatar
Timing chain too loose (maybe even a tooth off) and hitting guides, or you could have a rod bearing shot.
When you rebuilt the engine did you have everything checked by machine shop or did you just throw new parts in it without checking the rod ends and crank for roundness? Did you lube those bearings when you put them in? How did you breakin the engine?
Why did you do the rebuild? Never did say if this noise was there before the rebuild.
Old 02-01-2012, 06:16 AM
the47guy's Avatar
I didnt have a machine shop check it. I'm a helo mechanic and used the tools I had already to check the crank, rod ends, cylinder walls for roundness. Probably should of had a machine shop double check. Everything checked out fine per the FSM. I've double checked the timing marks and they are lined up. Top is at 11:55. Dark link is where it should be. I figured that wasn't it because it runs great, just that noise. Used assembly lube for everything I measured from the crank to the cam as well but I don't have the measurement with me at the moment. I'm wondering if the T chain is just a little too loose. Would a thicker head gasket fix that or would I be messing too much with compression at that point?
Old 02-01-2012, 08:31 AM
the47guy's Avatar
Bump*
Old 02-01-2012, 08:33 AM
Make sure it's not related to a bearing of a belt driven accessory. Like the Alternator, power steering pump, power steering idler. etc etc.
Old 02-01-2012, 08:42 AM
the47guy's Avatar
Will do thanks.
Old 02-01-2012, 10:07 AM
yotaman85's Avatar
this.. i rebuilt a motor once because it had a knock, put it together, still knocking. turned out to be the harmonic balencer.
Old 02-02-2012, 01:40 PM
the47guy's Avatar
Turns out it is coming from around my rockers. Any ideas?
Old 02-02-2012, 01:41 PM
Front or back? Maybe the valve cover is on too tight.
Old 02-02-2012, 01:55 PM
the47guy's Avatar
The back
Old 02-02-2012, 02:03 PM
Try backing off the valve cover nuts. You might have it too tight. Your only supposed to tighten those things lust past figure tight bearly squishing the grommets. If it's that though, you might not even hear the tapping from inside the cab.
theking11863
03-19-2016 09:36 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Jeffreynmandy
07-18-2015 08:26 AM
cars-guy
07-11-2015 07:51 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Noise when throttle barely pushed!
