No Power when engine warm (22RE)
Old 05-17-2005, 12:17 PM
Innocent Fool's Avatar
Hey guys
I’ve got a problem with my 91 Toyota extended cab 2wd truck
It’s got a 22RE engine in it and a manual 5spd transmission
It starts and drives O.K. when it’s cold but after it warms up it really bogs down until I hit about 2400 RPM. It idles fine and the Check engine light never comes on but it’s got no guts until I hit about 2400rpm.
It only seems to happen once the engine warms up. When the engine is cold it’s fine. ???
Unfortunately I don’t know much about fuel injection so I’m kind of in the dark about this one.
Any help would be appreciated
Thanks!
Old 05-18-2005, 07:36 AM
4Crawler's Avatar
Might want to check out the EGR valve and modulator, TPS: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml and AFM: http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml, check the timing, make sure all the vacuum hoses are connected properly and in good shape.
Old 05-18-2005, 10:47 AM
I'll Give it a shot
Thanks!
Old 07-02-2005, 05:03 AM
punkbek3886's Avatar
hey, it sounds like i have the same problem as you. mine will run bad until either i floor it or the rpms reach a certain point. have you found your problem yet?
Old 07-04-2005, 01:35 PM
Looks like I finally found the problem with my truck bogging down after it warmed up. Looks like the lame a$$ mechanic who worked on the truck replaced the O2 sensor with the WRONG unit. I got a replacement unit from the wreckers and the two units don't even look alike. On top of that he cut the connecting end off the old O2 and spliced it onto the one so he could swap it in.
Wasn't throwing any ECU codes but WAS reporting a rich condition that made the ECU cut the fuel back and run WAY lean.
How lame is that????
Reminds me of a line from a song I heard a while ago
"you pay for this and they give you that".....
So of course I'm trying to troubleshoot this thing and everytime it comes to checking the O2 I was thinking "no, it can't be that, it's brand new!"
So I think I'm going to start doing all me mech. work myself. At least I know it's done and been done properly!
What a pain in the arse!
Old 07-05-2005, 04:21 PM
haha i was just about to say, i posted earlier about us having the same problem, and it was. i replaced my o2 sensor and its running perfectly
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
God's Bounty Hunter
07-08-2015 12:54 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: No Power when engine warm (22RE)
