No heat 91 4runner
Old 12-29-2012, 03:29 PM
Quentin914runner's Avatar
No heat 91 4runner
I have a 91 4runner v6 3.0. I replaced my thermostat checked to see if the heater core was clogged the hoses get hot and have pressure but I have no heat to very little at all. It's winter and I can't defrost my windows let alone stay warm. Any suggestions?
Old 12-29-2012, 03:57 PM
NickMiller's Avatar
Did you "burp" the cooling system after you replaced the thermostat? Sometimes air bubbles in the coolant passages/hoses can keep coolant from flowing through the heater core causing the air not to heat up.
Old 12-29-2012, 04:03 PM
Yes I bless the lines a few times til there were no bubbles. Could it be the water pump? The hoses have pressure though.
Old 12-29-2012, 04:20 PM
NickMiller's Avatar
Was the heater on full blast (including the rear if you have it) when you bled/burped the system?
I'm just trying to get all the info I can before I try and guess what's wrong
Old 12-29-2012, 04:27 PM
Don't have a rear heater but I am not sure if heat was on when I tried it. I will go out and try then let you k ow if that works. Lets hope so.
Old 12-29-2012, 04:31 PM
NickMiller's Avatar
My heater hadn't worked well for years until I replaced my radiator which required a burping of the cooling system. Now it works even after a couple minutes of idling (at 35-40 degree outside temps BTW)!
I hope it works for ya!
Old 12-29-2012, 04:46 PM
It did not work at all. I put a new radiator in last year cause my old one had blown. Had to replace that at night in the middle of winter not fun. Now I did notice I am a little low on antifreeze but when I did have it full it still did not work properly. But maybe need to try again with heat in and burp it when full. Any other ideas in case that does not work?thank you for your help btw
Old 12-29-2012, 05:06 PM
NickMiller's Avatar
You have to add coolant while burping... The air bubbles take up space that should be replaced with coolant while burping. I'm NOT saying this would make a difference for your heater problem, but it's something to remember in the future
Have you tried backflushing your cooling system?
This thread talks about it... https://www.yotatech.com/forums/f115...-issue-105570/
Old 12-30-2012, 07:42 AM
Marc's Avatar
There is a valve for the heater on the firewall behind the throttle body.
Check to see if that's opening fully.
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
Poncho0206
07-10-2015 06:21 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: No heat 91 4runner
