No dash lights...any help?
I think you need to check the stereo wiring to make sure the green wire (which goes to the radio illumination on factory radios) isn't being used for something else. Most likely since it started with the stereo install. Might be the stereo install specialist thought it was a ground wire.
1990 Toyota 4Runner Car Stereo Wiring Schematic...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4″ Speakers
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4″ Speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
In the absence of schematic, it is Ok to "guess", but only connect things after one properly verifies, i.e., Physically tracing the wire, Doing resistance checks and or voltage checks. However, this is best left to those adept at wiring/electrical. IF not completely confident about electrical, take your time, wait for competent help, instead of guessing and breaking more things.
#27
A multimeter does a lot more (e.g., you can't really measure resistance with a test light). That's one of the reasons you hear it referenced so often on this forum. Too costly to afford one? No, I don't think so: http://www.harborfreight.com/7-funct...ter-98025.html
#28
I have DASH LIGHTS!!
Bswarm, thanks for the tip, it was in the stereo wiring, the installer had connected the green illumination wire to an orange wire w/white tracer that was then connected a light brown w/white tracer that connected to the white w/green tracer ( through the plugs ) which created a constant loop, I opened that circuit replaced the burned dimmer switch, turned on the lights and success! Put everything back together and all is well stereo included, thanks everyone for the input/info, hopefully this post can help someone down the road
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
zombie_barbarossa
10-02-2015 10:54 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
