NGK, Denso, & Other Spark Plug Wires
Old 12-19-2013, 04:07 PM
RAD4Runner's Avatar
Hi guys,
I posted in existing thread on "95.5-2004 Tacomas & 96-2002 4Runners" but was told to move to "2G 4Runner forum where the 22RE's are. 4Runners on here use different NGK wire sets and I have never seen this kind of complaint."
So here goes:
One of the NGK spark plug wires I got from sparkplugs.com (SKU: TX99A, ITEM : NGK9799) has developed a crack after just under 2 years. I expect wires to last longer than that.
Would like your thoughts AND, better yet, first-hand experience.
  1. Do you think it's indicative of NGK quality and I should get a Denso instead? OR
  2. Could it be just a fluke so should I stick to NGK? (Sparkplugs.com will give me some discount for repeat order).
  3. Does anyone have any experience that differentiates between NGK and Denso?
  4. Denso DENSO Part # 6714003 is actually less expensive than NGK9799 from Rock Auto.
Old 12-19-2013, 05:44 PM
85toy4runner's Avatar
just get spark plug wires from toyota and be done with it.. I asked a toyota master a couple years back and he told me only toyota spark plug wires only
Old 12-19-2013, 06:04 PM
94toy22re's Avatar
NGK and Denso are both oem parts for Toyota. I have the wires you have for about 4 years with no issues maybe you got a bad batch!
Old 12-19-2013, 11:29 PM
Cadin's Avatar
Does Sumitomo (Toyota OEM) make these as well? In my experience the NGK's have performed well, as have the Denso's, you may have a flukey set. I think equally important is to be sure your cap/rotor/plugs are all one of these makes and in good condition.
All that said, I recently had an FJ80 that burned a new NGK plug boot and caught the boot on the igniter on fire. I had only seen a cracked boot prior, so certainly check your igniter with a multimeter. What do your plugs look like?
Old 12-20-2013, 07:02 AM
snobdds's Avatar
As said, sumitomo is the OEM maker of Toyota spark plug wires, not NGK or Denso.
Go OEM as they will last for much longer.
Old 12-20-2013, 03:32 PM
and the good thing about toyota spark plug wires not only do they last longer but they have the date when they were made on the wires . I changed mine just because in 2011 and the old wires had a date of 2002 or 2004 cant remember . I didnt need to change them I just did as a maintenance item
sandyota
02-04-2021 11:16 AM
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: NGK, Denso, & Other Spark Plug Wires
