NGK BKR5EKB II in a 3.0 Is it possible?
Old 07-28-2012, 02:38 PM
mitfan311's Avatar
So I have a set of NGK BKR5EKB II (the dual electrode copper plugs) They are just sitting there in the box still in my garage. I was going to put them on my 98 3.4 but never got around to it and sold it a while back. I have two 95 3.0's. I dont want to go to the Autozone and buy new ones without the extra electrode if these will work. I wouldnt know what to gap it though. I looked all over but never saw a post on it. One of my 4runners came with and still has Bosch 4 point platnium or whatever and it's fine. I think i will give it a shot with just 1 plug and if it explodes and opens a black hole then I am sorry and take full responsibility.
Old 07-28-2012, 11:46 PM
totally a bro
Staff
vital22re's Avatar
the heat range may be too hot or too cold for the motor and could foul the plugs constantly. I believe they plugs are also different dimentions and may not fit as they should.
Old 07-29-2012, 02:38 AM
Pat8942's Avatar
BKR5EKB11
Multi-Ground Plug, 14mm Thread Size, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal Nut, ISO Length, Extended Projected Tip, Dual Ground Electrodes, .043" (1.1mm) Gap, Heat Range 5
BKR5EYA
Traditional Spark Plug, 14mm Thread Size, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal Nut, ISO Length, Projected Tip, .035" (0.9mm) Gap, Heat Range 5
ToyotaMD
08-17-2018 10:16 PM
nvwiggins
13
06-16-2016 03:05 PM
Ronnyboy
02-11-2016 05:57 PM
Boomer8404
09-10-2015 09:01 AM
anniesball
09-07-2015 11:20 AM
Quick Reply: NGK BKR5EKB II in a 3.0 Is it possible?
