new hitch install ..
Old 04-07-2007, 01:53 PM
slacker's Avatar
not hi tec or anything , but I thought I'd share ..
got it last week , but just didnt have time to install it .. It was a easy install about 1.5 hrs . actually should have only taken 1.0 hrs , but while I was under there , I did some other stuff ..
so in order to install , you have to remove the rear bumper , to install the frame brackets .. these didnt fit my frame very well , so I had to take them to the bench grinder , and remove a little material .
once the fame brackets are installed , the main drop brackets are installed for the hitch , and the bumper re-installed ...
Then the main section of the hitch is installed .. ALL bolts are then tightened ...viola .. a new hidden hitch .
sweet .. so now I can go pick up my TREKKERS .. well , parts and pieces anyway .
Old 04-07-2007, 01:57 PM
Elton's Avatar
looks nice
Old 04-07-2007, 01:59 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Yes, nice hitch...hooah!
What the hell is that black thing under the snow?
Old 04-07-2007, 02:11 PM
slacker's Avatar
thanks guys ..
it's a Toyota Trekker . basically (short answer) The first of the toyota 4runners produced, but a 79-83 style truck .
Old 04-07-2007, 02:25 PM
thook's Avatar
Ah yes, I know those. A fellow in this area has a burgundy one. It's a nifty little design. << envyyyyy! >>
Old 04-07-2007, 03:29 PM
slacker's Avatar
yeah .. I'm pumped .
I actually bought 2 1/2 trucks (trekkers) ... cant wait .
Old 04-07-2007, 06:44 PM
GV27's Avatar
+1. That's thing's a classic. Those things are rarer (much!) than my Alfa!
Old 04-08-2007, 06:46 AM
slacker's Avatar
yep .. they all even had # plates ..
I talked to winnabego a few years back , and was interested in purchacing the fiberglass moulds they used to build the beds and canopies , they told me they have been long distroyed .. so with the "1/2" truck I bought , i'm going to be building my own moulds .
Old 04-08-2007, 08:07 AM
Mark in MD's Avatar
I put that same hitch on my truck a week ago. Got it at JC Whitney. The instructions say you can just loosen the bumper brackets and slide the hitch on from underneath, but the hitch wouldn't fit. So I took the rear bumper off and I was able to line the hitch up with the frame from the back, and then tap it with a hammer to get it in there. Didn't have to grind. Nice tight fit. Ten bolts holds it on.
Old 04-08-2007, 08:42 AM
TNRabbit's Avatar
I put a similar hitch on my truck last November, but it was a DrawTite brand with 5,000 lb capacity. I wanted to be sure it would withstand whatever I wanted to tow! I was rear-ended by a Mazda Miata a couple of months ago and it did NOTHING to my truck (hit the hitch) but destroyed the front of his Miata!!
Old 04-08-2007, 04:30 PM
slacker's Avatar
yep ... this one is 5000Lb as well ... fit was good , and the grinding was most likely specific to my frame , I was rear ended a while back http://www.toyotafiberglass.com/myaccident.jpg . my fiber tailgate took it quite well .. I was impressed .
Old 04-08-2007, 04:35 PM
CoedNaked's Avatar
You're missing one thing though - the little Toyota rubber hitch cover/plug that all new Toyota trucks come with that have hitches. I picked up one from the local dealership just to complete the "look." I figure it's better than having a trailer ball/ball platform in my hitch all the time that ends up rusting out.
nvdesertrunner
05-11-2020 08:18 PM
4x4-runner
04-18-2017 09:08 PM
dropzone
08-11-2015 05:16 PM
58rennur4
08-04-2015 08:49 AM
defrag4
07-31-2015 10:50 AM
Quick Reply: new hitch install ..
