New fan cluch, new coolant leak.
Old 01-16-2012, 09:24 AM
woodyth's Avatar
I replace my fan clutch last week. today I went out to start it and noticed the dreaded puddle! I got a puddle of coolant under the truck so I get under there and look and it's coming from the region of the water pump. Would replacing the fan clutch cause the water pump to leak?
Do you guys think ordering the water pump and replacing it would help?
Kinda stumped here,
Thanks for the help!
Woody
Old 01-16-2012, 09:37 AM
snobdds's Avatar
Replacing the fan clutch has no bearing if the water pump is leaking. Replace your water pump and you should have no more leaks...
Old 01-16-2012, 09:41 AM
woodyth's Avatar
Well it did not leak before I changed the fan clutch........
Old 01-16-2012, 09:46 AM
snobdds's Avatar
That is simple minded logic right there...
Old 01-16-2012, 08:55 PM
Turd Furgeson's Avatar
Are you sure you didn't bump the radiator with a wrench,or the the fan clutch when you installed it? It doesn't take much to damage a tube on a radiator.
Old 01-16-2012, 11:25 PM
woodyth's Avatar
I can see where the leak is, now that I cleaned it up. Right at the bottom of the waterpump.
Old 01-16-2012, 11:26 PM
woodyth's Avatar
I can see where the leak is, now that I cleaned it up. Right at the bottom of the waterpump. Ill change it out tommrow and report back.
Old 01-16-2012, 11:51 PM
drew303's Avatar
more resistance on the water pump shaft.. probably all it needed to show its failure.
common failure dude, just replace the pump, $30
Old 01-16-2012, 11:52 PM
wyoming9's Avatar
Red face
It could be that as you swapped fan clutches your water pump seals were just about to fail.
As things got moved and slammed around it was enough to cause it to fail.
Then it could be just one of those random things that happen
Just curious why you changed the fan clutch??
Old 01-17-2012, 07:59 AM
woodyth's Avatar
it was bad would hardly turn , time for a new one, now off to the parts store to see f they got one or i have to wait a week to order it.
Old 01-17-2012, 04:02 PM
woodyth's Avatar
well new water pump in, was relatively harmless, hopefully when I walk out later there will be no leaks! Got the front bilstiens in too, now my truck sits weird, need to get the backs in!
Old 01-17-2012, 04:36 PM
snobdds's Avatar
Glad you got it figured out. Sometimes there is no rhyme or reason to parts failing...it just happens. Battries seem to be my achelies heel, they just like to fail without any warning.
Longbed 90
03-11-2019 12:38 PM
Corvoid
12-11-2015 11:21 AM
JUICE222
10-13-2015 08:50 AM
runnermedic
13
09-21-2015 05:20 PM
noahstancik
09-10-2015 10:47 AM
Quick Reply: New fan cluch, new coolant leak.
