Need some help with 3.0 Gauge Senders for Oil & Water
Old 01-21-2010, 07:19 PM
dieselcruiserhead's Avatar
Subject basically says it all... I stupidly forgot to pull the water temp and oil pressure senders from the 3.0 from my 1991 Pickup before I sold the engine. I am putting a Benz diesel into it and I need to thread the senders into the new engine. The question is.. Where are they, and what color are the wires going to them? I need to find a 3.0 V6 manual in a junk yard for a couple other reasons so hopefully I can pull them then and at least figure out what the wires are in the very complicated engine harness...
Would anyone be willing to let me know -- possibly post pictures? I know there are several coolant temp sensors as well for the computer, etc..
thanks,
Andre
Old 01-22-2010, 07:31 AM
OutlawMike's Avatar
The oil pressure sender is the easy one.
It is on the driver's side front of the motor, right down by the oil filter. The wire going to it comes off of the wiring harness that drops off the front driver's side of the motor and then heads over to the driver's side fender well.
Picture of oil sender, the smaller round part to the left of the oil filter in this pic. You can see the pigtail from the sender hanging down.
As for the temp sender, I can point you in the right direction, but I don't know which of the four sensors is the correct one on the sensor block. There is a sensor block on the back/top of the motor, down behind the plenum. There are four sensors and one thermal vacuum switch threaded into that block. Of the sensors, one has a single wire going to it and a spade connection, on the far driver's side. The two in the middle have two wires going to them. The one on the passenger's side has one wire with a plastic retention shroud. I never understood which one was the gauge for the dash gage.
Maybe someone else can point it out which sensor is the gage sending unit?
Sensor pictures:
Close up of the sensors with wires, shows wire routing, two from the left, two from the right.
Close up on the sensors with wires (far right single wire partially hidden by my hand):
Top view with harness and injector rail removed from the motor:
Old 01-22-2010, 08:07 AM
buckz6319's Avatar
Sensor pictures:
the one with the GRAY connector should be the Tempature Coolant Sensor.. and the Yellow/cream color connector is for the temperature gauge sending unit
Old 01-22-2010, 12:30 PM
CappyKD's Avatar
Whats the Green one then?
Old 01-22-2010, 01:46 PM
MudHippy's Avatar
From left to right:
1.Cold start injector time switch(yellowish connector)
2.No.2 ECT switch, or, A/C engine coolant temperature switch(grey connector)
3.Engine coolant temperature sensor(green connector)
4.Engine coolant temperature sendor(opaque spade connector)
Old 11-13-2014, 12:51 PM
Alaskan91's Avatar
Nice pics very helpful thanks
bigjstang
08-25-2021 12:41 AM
thefishguy77
07-30-2015 10:59 AM
88yodabasket
07-13-2015 01:32 PM
Coreyr384
07-10-2015 11:13 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Need some help with 3.0 Gauge Senders for Oil & Water
