Need more rear lift
Old 12-21-2011, 03:44 PM
Young Guy's Avatar
Question Need more rear lift
So i installed the rough country 5 inch suspension lift and i used the lift coil springs that the kit came with, however the rear is still noticeably shorter than the front.what can i do to lift the rear more? Should i look into buying larger springs and if so what do you guys recommend? Please help
Old 12-21-2011, 04:00 PM
BeMiceElf's Avatar
It would help to know what vehicle you are talking about.
I know its a 4runner, but knowing what Gen. would help out a lot.
I would try and lower the front first.
Old 12-21-2011, 04:04 PM
Young Guy's Avatar
good point, its a 1990 4runner
and as far as lowering the front i would like to stay away from that because i like how it sits right now and i dont want to mess with the torsion bars and have to get the front realigned again.
Old 12-21-2011, 04:06 PM
BoredOutnJackdUp's Avatar
Get taller coils? i think they make coil spacers?
Ive heard of people using jeep XJ coils. But i dont know what it provides as far as lift.
or just do a leaf spring swap
Old 12-21-2011, 04:10 PM
Young Guy's Avatar
Yah thats what ive been leaning towards because of the simplicity it provides and i have so much more control over my ride height.
For those who know, does leaf springs make the ride much rougher and does it truly get less flex?
Old 12-21-2011, 04:23 PM
BeMiceElf's Avatar
How much higher is the front than the rear?
What size tires are you running/planning to run?
Old 12-21-2011, 04:30 PM
Young Guy's Avatar
not much maybe an inch higher, and i have 33 inch super swampers on it
Old 12-21-2011, 04:37 PM
BeMiceElf's Avatar
Well, if I were you I would just lower the front then.
Getting an alignment will be cheaper then doing a rear leaf swap.
It will also ride better with some of the stress off of the t-bars. Especially if you have cranked them up already.
Flying91
45
04-11-2024 04:39 PM
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
akaphilly
07-09-2015 02:18 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Need more rear lift
