Need help truck sputtering
Old 08-30-2012, 06:09 PM
Meche yota's Avatar
Hi guys, I'm new here. I have a 1991 yota reg can 5 speed base model. My problem Is whe I crank it and take off down the road after about a mile or two it will lose power until it warms up. It's like sputters won't go unless I let off the gas. When it warms up it runs great not a glitch. Only does it when it's cold. I have replaced plugs,wires,rotor,cap,coil,pickup coil, tested fuel pressure it's at 35 psi. I have sprayed all vaccum lines with carb cleaner and didn't change anything. I'm now leaning towards o2 sensor and coolant temp sensors. Any help would be great appreciated!
Old 08-31-2012, 10:29 AM
Meche yota's Avatar
Anybody?
Old 08-31-2012, 10:56 AM
westjohns yota's Avatar
possibly a clogged cat? check your fuel pressure regulator hot and cold? fuel pump could be loseing power before it warms up, just a list of things, you said fuel pressure at 35 so i assume its a 22re? fuel injected
Old 08-31-2012, 10:57 AM
waskillywabbit's Avatar
CSI perhaps
:wabbit2:
Old 08-31-2012, 11:04 AM
Meche yota's Avatar
Yes it's a 22re. This morning I sat under the porch and let my truck warm up. No problem after warm up. I'm in Louisiana so the cold weather is really not a factor here.
Old 08-31-2012, 06:15 PM
Meche yota's Avatar
Incan now gear it backfiring though the intake maybe. I need some help guys.
Old 09-01-2012, 09:36 AM
Meche yota's Avatar
I pulled the o2 sensor off and Tryd to read the voltage with my meterand a propane torch.. It's doesn't read any voltage. Does it mean thati need a new one?
Old 09-02-2012, 09:19 AM
Meche yota's Avatar
Ok guy I got it fixed. I changed the o2 sensor, coolant temp sensor and thermostat. Runs like a dream. Tks for the help.
duckhead
170
11-13-2017 06:07 AM
MadMax48
07-03-2015 08:26 AM
thelifeadventure
07-02-2015 03:09 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
Quick Reply: Need help truck sputtering
