Need help fast!!! locking gas tank door is stuck
Old 07-28-2010, 07:34 AM
ilostmypants's Avatar
have you though about taking metal putty knife/scraper and putting a kink in it so you could flip the mechanism? or if the wife/girlfriend/mom/sister has a small bent icing spatula
Old 07-28-2010, 08:32 AM
dromomaniac's Avatar
just saw this post. My gas door has been 'stuck' for over a year. My solution was using an ice ax as a 'key'. Scared to pooh out of some Oregonian gas attendants (cant pump your own gas there) when I hopped out of the truck wielding the ax. Now days the hatch just flops around like the lower lip of a slack-jawed yocal--rather undignified.
Old 07-28-2010, 09:38 AM
AdamR's Avatar
this happened to me a few weeks ago. i got it open eventually and promptly removed the lock from the door.
Old 07-28-2010, 01:10 PM
BackGateYota92's Avatar
well right now i just took the tab and pushed it enough where the door is open about a inch and i can still open it. still trying to think what to do
Old 07-28-2010, 04:56 PM
  #25
Robert m's Avatar
before i put my fiberglass bedsides on, my gas door bounced around alot and it was really annoying. to fix it i took a small magnet and put it on the back side of the door and then put a small bolt with a flat head where the stock rubber bumper was. this held it enough from flappin around but was still easy to open.
Old 07-28-2010, 07:04 PM
  #26
myyota's Avatar
To bad the trucks arn`t set up like first gen 4Runners, were you can just pull the cable latch under the dash and the gas door pops open.
Old 07-29-2010, 06:15 AM
  #27
how hard you think it would be to do a swap like that??? this key has been giving me lots of problems
bigjstang
08-25-2021 12:41 AM
Eggslinger
06-08-2019 03:32 PM
skoti89
09-11-2015 07:46 AM
Fundy Rider
07-16-2015 01:35 AM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Need help fast!!! locking gas tank door is stuck
