Need help choosing spark plug
Old 07-26-2011, 01:47 PM
elblako91's Avatar
1992 toyota pickup 3VZE
Owners manual says must have gap of .031 and lists two options
NIPONDENSO K16R-U Part Number (3119)
NGK BKR5EYA
the DENSO has a gap of .028 and the NGK has a gap of .031
What is everyone else running? Should i get the denso and just regap it?
Old 07-26-2011, 01:54 PM
elblako91's Avatar
EDIT: found the denso's on amazon and they list the gap at .031?! So does anyone know which is it? .028 or .031?
http://www.amazon.com/Denso-K16R-U-T.../dp/B0012Q4GO2
Old 07-26-2011, 02:47 PM
93toyrunner2's Avatar
Old 07-26-2011, 02:49 PM
elblako91's Avatar
Ok so I can gap it to correct specs if needed. Does it matter which plug I go with tho?
Old 07-26-2011, 02:52 PM
NGK seems to be the popular choice on this site. I use them with no complaints at all. You should check the gap on all spark plugs you install, regardless if they say they are pre-gaped or not.
Old 07-26-2011, 02:58 PM
elblako91's Avatar
Thank you for your help. I'll head out and get the NGK's then and check the gap before I put them in.
rhill's Avatar
I've had good luck with the Denso's, but heard good things about the NGKs. Which one is cheaper or easier to find? When I bought both my trucks they had Bosch's in there. Changed out to Denso and it made a huge difference.
Old 07-26-2011, 03:05 PM
elblako91's Avatar
NGK's are in stock at the advanced auto parts a mile from my home. DENSOS i have to order so i think i will go with the NGK's. Toyota gave me that as an option so I don't see the harm in choosing them over the Densos.
Old 07-26-2011, 04:24 PM
drmix's Avatar
Yeah go with the NGKs. Definitely felt a difference when I replaced the crappy bosch's that came in it
Old 07-26-2011, 05:00 PM
elblako91's Avatar
Well just picked up the NGK's along with stopping by the toyota dealer to pick up some filters and some oil. Looks like I'll be busy tomorrow. I'll let you know what I think of the NGK's
Old 07-27-2011, 03:23 AM
TNRabbit's Avatar
I've used NGK, Denso, & Bosch. Had all kinds of miss issues with the Bosch, the NGK/Denso never a problem. Either are about the same. The only difference in the cheapest plugs & the $12/each iridium/platinum are the change interval (+100k with the Iridium/Platinum).
Old 07-27-2011, 03:30 AM
xxxtreme22r's Avatar
NGK v-power for me too. I love those things. BMW gets the Bosch though. As like the Toyota they only like Bosch plugs.
Old 07-27-2011, 04:50 AM
waskillywabbit's Avatar
I go to the dealer and say "I need spark plugs"
Tacoma cost me maybe $28 for 6
Whole thread about it
:wabbit2:
Old 07-27-2011, 12:37 PM
elblako91's Avatar
Pulled the plugs outside today. Felt like an oven
Anyways my spark plugs looked ok except for the fact the tips look worn down. Also broke a wire trying to pull out so I decided to go ahead and replace all the spark plug wires with some NGK's
Pictures
Truck ran fine before I pulled the spark plugs but after seeing the old ones I expect it to run even better and hopefully get some better MPG's
Old 07-27-2011, 12:42 PM
mihtoo's Avatar
ngk all the way!!! personal preferance.
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
raptor510
08-19-2015 02:15 PM
accuracy
08-04-2015 08:05 PM
defrag4
07-31-2015 10:50 AM
Quick Reply: Need help choosing spark plug
