NEED HELP!!! ASAP tranny seals
Old 11-22-2012, 07:40 AM
Peterbilt17's Avatar
i have a massive gear oil leak in my belhousing on my 1992 toyota pickup 22re 4x4 5 speed. i was wondering what type of tranny is in my truck???? i was told all of these trucks came with w56 trannys. i just replaced the seal and drove it for about 100 miles and now gear oil from the tranny is leaking in the belhousing...did i get the rite seal? or is it a possibilty something didnt seal rite? also ik there is the seal and then the cover goes over it. i used gasket maker to seal that cause i couldnt find a gasketfor that. is there a gasket for that?? also could i possibly need a speedi-sleeve for that seal??
I need to now asap what parts to pick up cause i need to fix it today!!
also is there a certain procedure adn torque specs for that cover??
another thing is to i just put in a new clutch set. i know the friction plates is going to be junk from the oil. should i just buy a hole new clutch set or just the clutch/friction plate?
THANK YOUU
Old 11-22-2012, 12:56 PM
rokblok's Avatar
There are different models of W56. A, B, C, and D. I'm not sure if the seals are all the same or if there are variances. Your dealer should be able to get you the right one with your VIN, pending your tranny is original.
And you can search and find torque specs for your bearing retainer in the front.
I would suggest a complete clutch kit replacement if your disc is contaminated.
Old 11-22-2012, 02:54 PM
waskillywabbit's Avatar
Gear oil from the tranny? You sure about that?
:wabbit2:
MadMax48
03-03-2020 10:33 AM
ToyotaMD
08-17-2018 10:16 PM
eggens
09-05-2015 12:16 AM
Quick Reply: NEED HELP!!! ASAP tranny seals
