Need a header, and soon
Old 07-26-2007, 06:29 PM
Lifelongtoy's Avatar
Question Need a header, and soon
Are there any other beside LCE. They seem a bit pricy, around $400. I'm looking to spend less than that.
I'v got a big crack in the 20 year old manifold and its just getting worse.
Old 07-26-2007, 06:53 PM
YodaPala's Avatar
pace setter is kinda cheap.
Old 07-26-2007, 07:52 PM
Tim_Snapple76's Avatar
idk if downey or thorley makes a set for the 22r/re, but they make some for the 3.0 so they have to for the 22r/re. good luck. tim.
Old 07-27-2007, 02:40 AM
TORTIS's Avatar
LCE makes a great header. i have the stainless steel header for my 22re and it bolted right on, and they have great customer service. Downey i believe makes a header, it's just everybody i talked to swore by LCE and now i see why. it is a tough choice, so good luck.
Old 07-27-2007, 06:45 AM
norcalsvx's Avatar
the lce is cermic coated as well so it keeps under hood temps way down
Old 07-27-2007, 06:51 AM
Which LCE header did you guys get. I'v seen more than one.
Old 07-27-2007, 07:00 AM
TORTIS's Avatar
stainless steel. so far, 4 years and zero rust.
Old 07-27-2007, 08:15 PM
steelydan's Avatar
I had a Doug Thorley on my 82 Hilux 22r... Over 300,000km and no cracks or leaking. Towed an 18' flat-bottom dragboat all over BC with a small Camperette on the truck. Had 5 transmissions replaced under warranttee... Those were the days...
Old 07-27-2007, 09:44 PM
pennywize's Avatar
got a thorley for my '79. i like it. under 200 bucks shipped from summit.
Old 07-27-2007, 10:29 PM
HelliphinoN8's Avatar
I've been in the custom exhaust industry for a while and 400 bucks is a decent deal. Most places will determine their prices based on the amount of power increase provided. If yer looking for something cheaper, you might just go down to the salvage yard and grab another manifold.
Old 07-28-2007, 08:48 AM
A lot of people are pointing me toward thorley. Is there more than one for the 4runner 22re? Any model numbers?
Old 07-29-2007, 07:10 AM
82yota's Avatar
I've got a Thorley on my 82. It works great. I did notice a difference in the low end and mid range. I haven't had it that long but it has not given me any problems. Got it this time last year. It is well built and you can get it ceramic coated as well. Mine has no emissions stuff on it at all but you can get it with the o2 sensor bung in it and that heat thing that goes to the carb intake for the hot air.
Old 07-29-2007, 04:42 PM
So the tri-y then?
Old 07-29-2007, 05:09 PM
pennywize's Avatar
tri-y thorley. you won't be disappointed.
link to summit and thorley headers. choose year and application...
http://tinyurl.com/2nojt5
Old 07-29-2007, 05:51 PM
What sort of modifications will I have to make? Or does it just like a glove?
Old 07-29-2007, 06:36 PM
jcfb's Avatar
Thorley is definitely the way to go if you're thinking aftermarket header. However, if you read this article, you will find that as far as power adders, the stock manifold is pretty good!
The best setup cost wise we have found is to use the excellent factory exhaust manifold
If you are wanting cost effective, find a junk yard and buy a stock manifold. I had a manifold crack on a '95 Corolla that my family owns and we just replaced it with a junk yard manifold. Cost was $30 and it hasn't cracked in the last 3 years that it has been on there.
Also, the Thorley just bolts on up. I've talked to several people who have installed the tri-y and they all say it fit like a glove. Obviously you are going to have to do some welding for the pipe, and you will need to bolt up to the header.
TheBFA
02-15-2020 06:55 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
voiddweller
09-28-2015 11:21 PM
toyotasaurus
09-24-2015 03:30 PM
DiggnDeep
09-03-2015 02:45 PM
Quick Reply: Need a header, and soon
