MSD Ignition Coil
Old 10-16-2013, 03:36 PM
mylittlepony1's Avatar
MSD Ignition Coil
Has anybody used one of these on there 3vze engines before? They seem like they would fit perfectly
Old 10-17-2013, 12:23 PM
RSR
RSR's Avatar
Some have had good luck w/ the 3vzfe coil swap... In addition to 8mm wires, setting plug gaps at supra specs, supra AFM swap, and timing adjustments (all using a wideband 02 to tune). Probably the more reliable way to go.
MSD's/aftermarket ignitions haven't been known to produce a lot of gains, and also have a tendency to fail and leave folks on these boards stranded I think. Believe it was to do primarily w/ water/corrosion issues I think, but if you search, I'm sure you'll find. Haven't tried myself...
Old 10-17-2013, 01:42 PM
250000_yota's Avatar
I did exactly as rsr said on my old 3.0. Ran great, but the coil didn't hold up off road. Make sure if you do get an aftermarket coil like an MSD or accel you get one of the high vibration coils.
Old 10-17-2013, 02:08 PM
oldblue's Avatar
msd makes good stuff that just doesn't last. my mustangs had a bypass setup so when the msd box took a ˟˟˟˟ and left me on the side of the road, i could bypass it and get home. stick with a stock yota coil, you'll never see or feel a difference with an msd coil in your truck.
Old 10-17-2013, 02:16 PM
Gamefreakgc's Avatar
My coil was damaged so I decided to try out an aftermarket coil and widen plug gaps. No noticeable improvement in performance.
Old 10-17-2013, 08:08 PM
RSR
RSR's Avatar
Most who run the supra coil keep their OEM one installed just in case...
And according to this forum, racing vehicles actually run two MSDs w/ a switch in the event one fails: https://www.yotatech.com/forums/f116...-system-92259/
And this covers a lot of the water and other issues:
MadMax48
03-03-2020 10:33 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
voiddweller
09-28-2015 11:21 PM
JHalcyonM
09-14-2015 01:10 AM
Quick Reply: MSD Ignition Coil
