Mpg gain?
Old 07-22-2013, 02:53 PM
Edionne13's Avatar
Originally Posted by 91 4Runner
Re-gear to 4.88's then once you SAS sell the front differential to fund another set of 4.88's for the solid axle. ISR mod, manual hubs (if you don`t already have them), fresh tune up, free flowing exhaust. 7mg VAFM, upgrade your injectors, better fuel and keep your foot out of it!
That`s about it!
Might sound like a dumb question but injectors any good brands you'd recommend? ISR mod ill have to research that
Old 07-26-2013, 05:22 PM
wallytoo's Avatar
i wanted enough data to review before posting about gas mileage. soooo.
i've now put over 1,600 miles on my 87 runner (22re, manual 5-speed, 30x9.5s)
i've consistently been getting 21 to 23 mpg, and i've verified my odometer reads correctly (on a few measured mile sections). so far as i can tell, other than the slightly larger tires, the rest of the vehicle is stock, and most of the mechanical parts are probably original (98,xxx miles). i believe it still has the original plug wires in it.
i go 60 on the interstate max, but the mileage has been from "mixed" rural driving - plenty of 30 to 35, 40 to 50, in town. i'm pretty happy with those numbers, not a huge dropoff from my '95 legacy, which was 25 to 30 mpg (best tank was 33 mpg)
key is not to be running at 3K, keep it around 2200 to 2500. don't put the pedal to the metal all the time. it can be done. most recent fill-up was at 340 miles on the tank, and i only put 15.2 gallons in. i know i can drive it until i can put 16.5 in it, since i've already done that.
Longbed 90
03-11-2019 12:38 PM
primordialbeast117
12-19-2015 12:23 PM
kawazx636
09-29-2015 08:22 AM
83
18
09-21-2015 06:15 PM
Gargoyle_Runner
08-28-2015 01:36 AM
Quick Reply: Mpg gain?
