Motor dies when i push the braked! Any advise?
Old 11-01-2012, 05:45 AM
SPARKS89's Avatar
NGK plugs seem to be the most popular here. NGK is standard issue for these trucks anyway.
So you took your 22re top end and put it on a 22r bottom. The problem got better after the valves were adjusted, but it's still not right. Have you done a compression check?
Old 11-03-2012, 09:32 AM
tys_toyota's Avatar
I adjusted the throttle body as advised. There was a little line drawn on it where i assumed the old setting was, so i just turned it forward till it was lined up amd it runs way better than before. And yes, we put my 22re top end on a rebuilt 22r bottom end with a header and glasspack!
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
v_man
07-23-2015 04:01 PM
msane99
07-17-2015 10:13 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Motor dies when i push the braked! Any advise?
