Low shift points. 22re 4wd AT
Old 03-07-2011, 08:27 AM
toyotaPmanager's Avatar
AT trans shifting from 1st to 2nd at 15mph and to drive at 20 then overdrive at 25 once warm no matter whether at 10% throttle or on the floor. really leaning towards a out of adjustment tps. I have adjusted the throttle cable to toyota specs. that adjustment had no effect on shift points.
Old 03-08-2011, 06:14 AM
No one? Am i the only one who has had this problem? i did some testing last night on the tps. It looks like my problem might be there. Replacing it with a known good tps tonight and i will keep everyone updated.
Old 03-09-2011, 06:14 AM
replaced the TPS yesterday evening and all is good in my world now. Truck shifts at varying rpms depending on throttle input and will know also downshift when needed.
Old 03-11-2011, 06:28 PM
annoyingrob's Avatar
I was going to say check the transmission computer for throttle position signals, but you already figured it out
jbv808
08-06-2021 04:47 PM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
Coreyr384
07-10-2015 11:13 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Low shift points. 22re 4wd AT
