low oil pressure..should i be worried?
Old 09-27-2012, 12:57 PM
Philbert's Avatar
Originally Posted by Toy3sgte
Rat tat tat. I doubt that was oil pump gears. It could 've been valves. But if your oil was that low I wouldn't be surprised if you damaged your rod bearings
I thought more about it last night and that's the conclusion I came to as well - valves tapping, not oil pump.
I've never taken a bottom end apart and with this mileage, I think I'll just keep it going and keep a better eye on the oil level/pressure so it doesn't get in the danger zone again.
I'm puzzled that I was so low, after adding a quart a month ago (and never having had to get in the habit of adding oil in between changes before).
I've had the truck 10 years and put 74,000 miles on it - got it with 200,000.
Thanks
Phil
Old 09-27-2012, 02:48 PM
92 TOY's Avatar
hmmm....following this.
nothing to add, just trying to keep up.
Old 01-08-2013, 12:49 PM
Philbert's Avatar
Just letting you guys know I have good oil presure still since I topped off with oil. No strange sounds since.
Now I just have to figure out my leaky head gasket issue
Old 01-08-2013, 01:01 PM
HighLux's Avatar
The low oil level was starving the chain tensioner for oil.
The noise you heard was your chain without tension.
Keep oil in her...lol.
As far as were your oil is going...thats another can o worms.
Old 01-08-2013, 01:25 PM
  #25
Philbert's Avatar
It's actually coolant leaking from the HG Going to try re torquing the head bolts
Old 01-09-2013, 04:14 AM
  #26
Pat8942's Avatar
Low oil pressure could be caused by worn main bearings or a clogged pickup screen, on a cold start listen for a deep knocking sound that doesn't last long, if you hear that it's worn mains, if the clearance between the crank journal and the bearing becomes to great it will not hold a film of oil between them and knocking and loss of pressure will result.
Old 01-09-2013, 06:55 AM
  #27
Philbert's Avatar
Thanks Pat. I think you mentioned something similar earlier in the thread. Just was going through my subscriptions and came across this thread...wanted to update it. Not experiencing the rat tat tat at cold start anymore since putting more oil in, so I think I am good for now. If it returns and oil level drops, I will update thread.
Thanks again everyone
jbv808
08-06-2021 04:47 PM
Eggslinger
06-08-2019 03:32 PM
Jeffreynmandy
07-18-2015 08:26 AM
Coreyr384
07-10-2015 11:13 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: low oil pressure..should i be worried?
