loss of power after new timming belt
Old 07-29-2007, 01:38 PM
olharleyman's Avatar
So yesterday I replaced my
timing belt
idler pulley
water pump
thermostat
pulley tensioner
power steering belt
alternator belt
fan belt
coolant
oil and filter
all at 215,565 miles. I talked with a Toyota master tech and he told me to set the timing at 7-8 degrees above 0 , so I did just that and now I have good power in the lower gears but when I shift into 3rd Thur 5th there is a total lack of power compared to how it was running with the old stuff. Also the gas mileage so far has gone to the toilet 30 on a quarter tank so far and not looking to be getting better. Has anyone else have this issue after doing the timing belt?? Any ideas how to make the power back and mileage come back?? is the timing the issue here?? if so what should I set the timing too to get the power and mileage back?? any info will be greatly appreciated
Old 07-29-2007, 01:53 PM
ChickenLover's Avatar
Your problem is more than likely your timing. It should be set at 10-12 degrees btdc.
Old 07-29-2007, 02:44 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Yep....you're timing is retarded..hehe.
BTW, that master tech is probably thinking of the 22re...or he's retarded, too.
Old 07-29-2007, 02:48 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
dont know anything about it except i read in chiltons that its to be 10-12 degrees
Old 07-30-2007, 09:17 PM
Just Want To Say Thanks To You Guys Set The Timing To 12 Btdc And The Power Is All Better. Thank You Again
Sleaker
08-26-2020 06:03 AM
tj884Rdlx
08-28-2015 12:04 PM
WellsR
12
07-31-2015 03:27 PM
gmonnie123
07-26-2015 02:44 PM
cgilley
07-25-2015 10:55 PM
Quick Reply: loss of power after new timming belt
