Lock Knob Holder Install?
Old 03-11-2012, 04:18 PM
MacGyver!'s Avatar
I cannot seem to install the lock knob holder (trim around lock knob on doors, my driver side was missing when I bought it). Does anyone know how to do this? It seems so easy, but it just keeps popping out...
To make matters worse, I tried to remove the passenger side piece to inspect it to make sure the part I had was correct and broke it . Here is a picture of the new one and old (broken one). Any ideas?
New Holder:
New and Broken Holders:
Door knob:
Old 03-11-2012, 04:24 PM
whelan709's Avatar
looks like you have to melt those plastic tabs to install it, I'd just epoxy it in.
Old 03-11-2012, 05:18 PM
MacGyver!'s Avatar
Yeah, I was thinking the same thing about the melting. I'm not sure how I would do that or what to epoxy it too.
Old 03-11-2012, 05:27 PM
rworegon's Avatar
To melt those tabs (also, not sure what to use to melt them) or epoxy them, you would need to pull the door panel off and access those legs from the back side on the new piece is in position.
A local auto body shop may give you a hint.
Old 03-11-2012, 06:02 PM
whelan709's Avatar
something like an iron on really low heat, just enough to make it pliable too much heat will burn t easily.
Old 03-12-2012, 02:32 PM
MacGyver!'s Avatar
Thanks for the advice. I'll probably try to use a flat tip on a soldering iron to melt the post. If I come across any earth shattering revelations, I'll be sure to share.
Old 03-12-2012, 02:35 PM
MaK92-4RnR's Avatar
they usually crack and break again anyway... mine came with all of them and idiots who are impatient to get out of the truck usually "pull up the lock" and grab these little guys too and end up breaking them. rather than waiting for me to turn the truck off ( locks pop open when the car is turned off )
Old 04-22-2012, 10:57 AM
cred92's Avatar
Were did you find new ones of those mine are both broken and ive tried Toyota parts east do you happen to know the part number and I can call my Toyota dealer n see if they can get it.
Old 04-28-2012, 03:14 PM
MacGyver!'s Avatar
Sorry for the late reply, the part number that I got from the dealer is 69751-12030-J0, they had to order it for me; I still haven't installed them yet, too many other things to do. Let me know if you get one installed so I know how it goes.
Good luck!
Old 04-28-2012, 03:31 PM
Staff
DeathCougar's Avatar
Those tabs have to be melted a little, to attach it. Ergo why you broke the other side prying it out
westonian18
05-01-2020 06:38 AM
okamikai
04-30-2018 10:19 PM
TDonkey
07-26-2015 10:14 AM
rushw
07-18-2015 01:46 PM
cyclist231
07-07-2015 12:56 PM
Quick Reply: Lock Knob Holder Install?
