Light sputtering in 91 4 runner
Old 12-28-2010, 03:44 AM
Quentin27's Avatar
Just the other day my 91 runner started to sputter a little bit when I hit 40-50 mph. It then also started to do it at 20-35. It then stoped for a few days after I put fuel cleaner in cause it started right after I had gotten gas. It is now doing it again. Any advice? Thanks
Old 12-28-2010, 07:57 AM
justin_4runner's Avatar
when was the last time u did tune up? fuel filter and what type of gas u buying?
Old 12-28-2010, 07:59 AM
sebastianholmes's Avatar
its usually helpful if you tell what kind of motor it is...
Old 12-28-2010, 10:43 AM
Quentin27's Avatar
I haven't done tilune up I just bought it 3 weeks ago and I use Regular gas. And it's a v6 3.0
Old 12-29-2010, 08:22 PM
tebro27's Avatar
Good evening, try disconnecting the EGR valve.
Old 05-02-2011, 10:08 PM
banoobee17's Avatar
i have a similar problem too like when i started it up the motor shakes and it sputters out of the exhaust but the motor shakes too so. i changed the coolant temp and fuel filter and spark plugs still the same symptoms motor shakes etc so i been reading bout simliar problems thinking bout changing the tps and o2 sensor but i was curious on what u guys might think it is and when cold or hot below 3000 rpms it sputters but not so much any above 3000 rpms
Old 05-02-2011, 10:14 PM
how many miles are on that motor? have u checked the wires or replaced them? also injectors might be your problem, have u checked to make sure they are spraying right and not leaking? some more idea....
Old 05-04-2011, 10:04 AM
banoobee17's Avatar
well the motor have bout 15,000 replaced my fuel filter and spark plugs i replaced some wires that i though they were bad and i also checked if they were firing with a timing light and i didnt see any leaking injectors but what happen i drove to school one moring i alwasy warm it up i drove it kind of hard then when i got out of school it started sputtering
Old 05-04-2011, 10:05 AM
banoobee17's Avatar
i also siphoned some of my dads gas from another 4runner cause i was low on gas but i didnt know he was runnig with premium octane and i already had 87 oct in my could hat mess things up with compression or something. how can i check if my injector are spraying right?
gillesdetrail
11-19-2019 12:56 PM
Aleeex_u
06-05-2016 06:52 PM
Peach
07-03-2015 09:30 AM
sonic concepts
07-01-2015 02:33 PM
ItsAtoyotaLIFE
06-21-2015 11:45 AM
Quick Reply: Light sputtering in 91 4 runner
