lean out on 3vze
Old 08-12-2008, 06:33 PM
tarpon40's Avatar
lean out on 3vze
What are the potential causes other that the adjustment on the throtle body, that causes an engine to lean out?
Old 08-12-2008, 07:34 PM
mmcpeck's Avatar
Bad O2 sensor, if it was telling the ECM that the exhaust was too rich, then it could lean out the mixture.
Bad coolant temp sensor, telling the ECM that the engine is hot when it's cold, causing it to run lean when cold.
Just some.....
Old 08-12-2008, 07:52 PM
jason191918's Avatar
hole in intake that allows more air in after the MAF/VAF
Old 08-13-2008, 12:46 PM
abecedarian's Avatar
fuel pump, fuel filter, fuel pressure regulator, injectors, AFM calibration, vacuum leaks, low battery voltage
JonG85
01-18-2023 04:31 PM
Ditch Doc
10-27-2015 03:20 PM
Kamaloha
10-16-2015 05:13 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
the_supernerd
10-01-2015 09:20 PM
Quick Reply: lean out on 3vze
