Leaf spring identification
Old 08-26-2009, 01:23 AM
broyota's Avatar
I have been wanting to find out if my 1986 toyota 4wd pickup has 1 ton or 1/2 ton springs. I had a 1987 4runner before, and it wasn't nearly as stiffly sprung as this one is. It will bounce the rear end off the ground when I go over bumpy sections of road, and it won't flex at all (it flexes out entering my driveway, and lifts the right rear tire off the ground). I am sure it needs shocks, but even with the shocks off, I cant get the rear springs to compress (by jumping on the bed). The springs look stock, with the stock rubber bump stops. I don't know if it has to do with the spring type, but it has green paint on the outer leafs under the shackles.
Old 08-26-2009, 01:29 AM
malteserunner's Avatar
Pics?
Old 08-26-2009, 01:35 AM
broyota's Avatar
I will get pics tomorrow.
erm, today, 7 hours from now (after I go to bed and wake up when its light outside)
Old 08-27-2009, 11:05 AM
broyota's Avatar
Here are the pics:
Old 08-27-2009, 11:40 AM
Sponsor
Tofer's Avatar
as far as i know there wasnt an option for "1 ton" springs..... they are what they are.... Stock springs with Crappy shocks. get new shocks and wheel hop will go away.
Old 08-27-2009, 11:55 AM
camo31_10.50's Avatar
only way to help with your problem...
NEW SPRINGS>.
your riding on the overloads that is why is soooo stiff..
mine is the same way..although i have a little flex..lol
new shocks will help..but the problem will still be your leaf's..
Old 08-27-2009, 12:07 PM
broyota's Avatar
I will probably get some OME springs when I have the cash.
As for shocks, they look pretty bad (front ones are leaking, and all 4 look cheap). I think Rancho RS 5000s would work.
ZGjethro
06-07-2017 11:04 PM
JookUpVandetti
09-30-2015 08:58 AM
Cycles
09-29-2015 06:37 AM
oldblue
09-28-2015 04:07 PM
83
09-27-2015 04:13 PM
Quick Reply: Leaf spring identification
