Late model Intake, supra afm, and long block
Old 01-06-2011, 07:16 PM
CitrusTheDragon's Avatar
Originally Posted by MaK92-4RnR
because you need to pass smog. you're not gonna see any increases in power what so ever, so whats the point of screwing with it and jeopardizing your legality?
Full legal swap, talked to my smog guy at work about it. He says if it looks stock, and passes no one will know the differents
Old 01-06-2011, 07:19 PM
MaK92-4RnR's Avatar
go for it then.
Old 01-06-2011, 07:30 PM
sebastianholmes's Avatar
why wouldnt he see a diference? its going to turn it into an F-1 car but the AFM swap has shown good results and so has the newer intake swap so put together it should be quite noticeable, and hopefully get him some MPG's too
Old 01-06-2011, 07:39 PM
Ok guys here is the story. I took my truck to my work and ran some test on it. I have a cracked intake manifold, a blown head gasket, my timing chain cover has holes, my exhaust is being held on with clothing hangers, my exhaust manifold whistles from pin holes all over it, and the dyno says I have 55hp with 65ft/lbs of torque. Now does anyone think I just might see an improvement?(BTW I will be smoging and dynoing after the swap)
Old 01-06-2011, 07:41 PM
  #25
myyota's Avatar
Originally Posted by CitrusTheDragon
See thats funny I read a post that said it should work. In fact the guy says he used one off of a cressida
http://www.celica-gts.com/forums/index.php?topic=7543.0
I didn`t think it would work, i might have to try it and see.
Old 01-06-2011, 07:46 PM
  #26
U am going to look at both, I can buy remand ones from and see if they match up
  #27
hahahahahahahah sounds like you would see improvements if you put it in neutral and rolled it down a steep hill!!! that thing needs some major TLC!!! But forreal, i want pics when this gets started! should be a peppy little 4 banger when you finish, gonna be sweet!
Old 01-06-2011, 08:05 PM
  #28
Yea the previous owner didn't really do much in the way of maintenance. In the first 6 months I had it clutch crapped out, brakes failed, half shaft started popping and the engine start bathing it self in fluids. When my coolant looked like a whipped chocolate and smell like eggs, I knew something was very wrong
Old 01-06-2011, 08:08 PM
  #29
Ok now back to topic, I have heard alot about intake and that stuff, but what about injectors? exhaust? plugs? wire cap and rotor? any suggestion there
Old 01-06-2011, 08:31 PM
  #30
i know that denso plugs do the best on yotas
Old 01-06-2011, 08:33 PM
  #31
myyota's Avatar
You can use the stock injectors, use a Denso cap, rotor, plugs, and plug wires. For exhaust, a good header and 2 1/4'' exhaust will work good.
Old 01-06-2011, 08:40 PM
  #32
since he is getting much more airflow shouldnt he get better injectors or no? im still pretty noob at this kinda stuff so im learnin here too
Old 01-06-2011, 08:45 PM
  #33
myyota's Avatar
He should still be ok with the stock injectors, but it would be a good idea to send the injectors out to be cleaned and rebuilt.
Old 01-06-2011, 08:53 PM
  #34
Any suggestions on type of header???? That won't cost me a grand
Old 01-06-2011, 08:58 PM
  #35
Buying new ones not taking a chance
Old 01-06-2011, 09:03 PM
  #36
myyota's Avatar
A Thorley header is good, i don`t know what they cost though.
Old 01-06-2011, 09:17 PM
  #37
I kinda noticed that but the price is a little high, then again I have heard its worth it. Anyone know where to buy them?
Old 01-06-2011, 09:21 PM
  #38
myyota's Avatar
LC Engineering sells them, but do a little searching and you might be able to find it cheaper.
Old 01-06-2011, 11:29 PM
  #39
I just don't want to end up with crap
Old 01-06-2011, 11:48 PM
  #40
myyota's Avatar
From what ive read here, Thorley headers are a good part, many here have them on there trucks. If Downey was still in business i would recomend one of there headers to you, that`s what i have on my 4Runner, and it wasn`t cheap but its a very good quality header.
Quick Reply: Late model Intake, supra afm, and long block
