Last wire after HG, cant figure out where it goes
Old 10-16-2011, 04:30 PM
Drillin_guy's Avatar
Im getting close to finishing to being finished and cant figure out where this last single blue connector goes. Any Ideas?
Old 10-16-2011, 04:31 PM
Oh yeah, its on an 87' 4Runner, 22re, 5 spd
Old 10-16-2011, 07:22 PM
angrybob's Avatar
Directly to the right of the cold start injector about 2" and down about 2", there is a temp sensor with a male spade on it. Plug it in.
Old 10-16-2011, 07:39 PM
Datsayota's Avatar
I agree with angrybob, looks like the coolant temp sending unit wire. If you already have one plugged into the coolant temp sender, make sure it isn't the one for the oil pressure sending unit - same type of connector. The coolant temp sensor has a wire color of yellow with a green stripe. The oil sending unit has yellow with a black stripe
It is possible that this blue one is not used.
Old 10-16-2011, 07:45 PM
Datsayota's Avatar
Here is a copy of the diagram - hope it helps!
Old 10-16-2011, 07:56 PM
Yup... thats what it was, the PO had installed an aftermarket temp gauge and sending unit so thats why I had no home for the wire. Thanks for the help though Angrybob and Datsayota!!!
smthwsn357
05-01-2024 07:28 AM
Sleaker
08-26-2020 06:03 AM
montanatruck
02-26-2017 07:07 AM
Steven.m.paulk
07-13-2015 01:40 PM
Edionne13
07-09-2015 01:59 PM
Quick Reply: Last wire after HG, cant figure out where it goes
