Large spring fell out from under dash (86 22re 4x4 auto)
Old 01-31-2013, 08:04 AM
Schnit's Avatar
Hey everyone,
First off, it's colder than hell (zero degrees F) here in Minnesota so I'm posting this before I spend 10 minutes out in the cold poking around under a dark dashboard.
Today while driving I had a large, aprox 6-8" spring fall out from under the drivers side of my dashboard. A brief search on google returned nothing relevant. Anyone familiar with where this thing goes? Throttle return and brake pedal both seem to spring back to normal.
Any help would be appreciated!
Old 01-31-2013, 08:07 AM
Toyota~Boy's Avatar
It's one of the springs that connect to the pedal assembly. Brake, clutch, or has pedal.
Old 01-31-2013, 08:10 AM
Toyota~Boy's Avatar
Of you look at your pedal assembly you will see a pin the goes through each assembly holding either the brake booster rod to the brake pedal or the master cylinder to the clutch pedal. One of those is missing the spring. Now figure out which one. After that look up under the steering wheel down below the plastic dash trim. You will see some little holes. That's we're the other end of the spring hooks in. It's used to keep your pedal pulled back
Old 01-31-2013, 08:14 AM
snobdds's Avatar
Probably the spring that connects to the clutch pedal. That is about the correct size without seeing a picture...
Old 12-23-2021, 10:30 AM
Currinson's Avatar
Originally Posted by Schnit
Hey everyone,
Did you find out what the spring was. I was just replacing the heat resistor in my sons 2001 Toyota Camry and that same spring fell down when I took the cover down, no idea where it goes to, any thoughts? I t is 6-8 inches long but there is also an o ring on one side
Old 12-23-2021, 11:39 AM
wallytoo's Avatar
welcome to 2013.
how would you know that the spring in the camry is the same as the spring from the truck? there isn't a picture posted in the thread showing the spring.
perhaps ask in a camry forum that covers the 2001 model, rather than a truck/4runner forum that covers '86 to '95.
Old 12-24-2021, 07:24 AM
scope103's Avatar
..., it's colder than hell (zero degrees F) here in Minnesota ...
I haven't spent a lot of time in MN, but I got the impression that the locals think of that as a pretty nice day!
MO transplant
04-23-2023 11:58 AM
06-01-2021 01:51 PM
Colington
03-08-2020 09:51 AM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Large spring fell out from under dash (86 22re 4x4 auto)
