Knock Sensor, will it run without it?
Old 05-31-2009, 02:49 PM
Azca's Avatar
Angry Knock Sensor, will it run without it?
Okay gents I have about had it with this engine. I am replacing the fuel injectors because of a leak (second time in two months the manifold is off) and have found that many of the wires on the driver side of the engine are toasted. I have replaced some of the connectors and need to pick up a couple more. I have a new knock sensor wire but the darn thing looks toasted right at the point it passes between the block and intake manifold. I am tempted to try to sleeve the wires with heat shrink as I really do not want to tear it appart. In fact if I have to do it, I will just swap the engine at this point.
So will this thing work without it?
Old 05-31-2009, 03:40 PM
94toy4x4fever's Avatar
yeah the engine will run with out it! I wouldent do it tho besause the knock sensor is there for a reason! it retatds timming when the engine knocks/pings
sandyota
02-04-2021 11:16 AM
icentropy
09-16-2020 02:47 PM
smiley52
07-11-2015 05:16 AM
nick b
07-11-2015 04:38 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Knock Sensor, will it run without it?
