just picked up 93 toyota pickup - stuck engine
Old 08-14-2011, 04:19 AM
pperry71's Avatar
just picked up this 93 pickup 4x4 ext cab V6 automatic trans . bought as unknown condition.
was told it has been sitting a year or so. i cannot turn the engine by hand and trans shifter is also stuck in park . story go's is it was the guys daughter's truck and it quit on her. dad said her not so smart Dumb A#@ boy friend took it home and started to tear it apart.
so far i see the alternator is gone, cap-rotor-wires gone, & some fuse's gone from the box under the hood. i do not have the missing parts. maybe the cap was pulled to get the ALT out .
im hopeing to get the engine to turn over but hard to get something on the crank pulley. what do you'all suggest i look for. starter hung up ? belts froze to pulleys ? could the trans hold the engine ?. does it have a timeing belt or chain ?.
thanks....perry
Old 08-14-2011, 09:00 AM
drmix's Avatar
V6 has the timing belt. Not too sure how automatics work when there in park (only deal with manuals) but im guessing you should be able to rotate the motor. Im trying to remember from when I did my HG a while back but I think you should be able to access the crank pulley from the bottom with a ratchet or breaker bar
Are those all of your yotas in the back?
Old 08-14-2011, 11:07 AM
pperry71's Avatar
just have the one grey and white yota. other is a S-10 in the back ground.
i got the fan and shroud off. used a pipe wrench, the engine is locked tight. pulled all the plugs , pulled inspection plate & checked the starter gear for hang up. no signs of anything wrong. but engine wont turn. they must have got it hot and siezed up .
i got it to go into nuetral, there is a manual over-ride button for the shifter lock....DUH....
guess ill keep digging at it , but i bet the rods are siezed to the crank .
Old 08-14-2011, 12:45 PM
JJGN's Avatar
Any sign of water in the oil? Try to put some Marvel Mystery oil in each cyl, and let it sit for a day or two and get a wrench on the crankshaft bolt. Go slowly, the rings may be stuck to the cyl. walls and need a little lube to free them up. Also, take off all other belts.
Old 08-14-2011, 03:18 PM
pperry71's Avatar
yep, got the cylinders soaking down . will try in a few days/week. all fluids look good. no signs of water in oil or cylinders. i bet oil pump went bad.
i know 3.0 engines are probaly expensive. whats a rebuild cost ?.
Old 08-14-2011, 03:55 PM
drmix's Avatar
If the motor needs rebuilt I would recommend just going with a 3.4 swap. No use in putting a lot of money and work into a 3.0 especially with the bad gas mileage and low amount of power they put out but thats just me. I plan to swap out mine when she finally goes.
Old 08-19-2011, 02:55 PM
chaosharmonized's Avatar
im in the middle of swapping my 3.0 out for a 4.3 vortec....i got an s-10 im stripping for parts (i'll be sad to see that go i've had it for 10yrs) and i bought the 4.3 vortec "w" with 80k for 400 bucks....there is a ton of info on here for a 4.3 swap. you might want to look into that
Old 03-17-2012, 04:00 AM
pperry71's Avatar
good idea on the 4.3. have to look into that. i may pull the engine from my 90 yota and put into the 93
Old 03-17-2012, 06:57 AM
jammin962's Avatar
IMO if you're going for better mpg the 4.3 isn't much better than the 3.0... I'm helping a buddy swap a tired 4.3 out of his zr2 sonoma for a 5.3 H.O. and one of the main reasons he's doing that is the 4.3 was still only getting 16-17 mpg
If you don't want to rebuild the 3.0 find a good junkyard motor ..or get one that someone else took out for a 3.4 swap. and BAM drop a running 3.0 in her and have two running trucks... I wouldn't gut your 90 it looks clean.
taraf
09-24-2015 08:33 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
paxanders
06-21-2015 06:29 AM
nyk08trx
06-18-2015 09:01 PM
Quick Reply: just picked up 93 toyota pickup - stuck engine
