just fail smog test in cali.........
the truck runs good on the highway, on the video, I am pushing and holding the pedal down and as you can see the rpms goes up and down. it sure look like I am doing it but I am not. however, I found out the PAIR reed valve makes a clicking noise and when i take off the little vacuum hose, it stop right away.
Could this be a rev limiter issue??? Just wondering if this could also have an ignition issue. I beleive where your at in Willits, which is NorCal, the smog test will consist of 2 idle speed test which is where the tech only idles the engine and not on a roller system, dyno machine, like here in SoCal.
Hey Citrus, I also have my smog licence, here in SoCal we have to have the Advanced Emmisions licence. Dont remember if Sacramento requires the Advanced or just Basic.
#28
I don't think he is moving his foot to make it fluctuate, there is a prob some where. Stay with us there is an answer somewhere.
Necessity is the Mother of all inventions.
#29
To the original post.
Have you ohm tested the TPS? Checked its sweep? That would be a good place to start. Check out the FSM for specs and which terminals to check.
#31
It depends on what county you live in. Some don't require a dyno. As a smog tech you should know this. Just enter the VIN and the computer tells you which test is required, dyno (enhanced) or static (basic). Some counties only require a smog when you change ownership.
#32
Smog problem too!
I took my 86 4runner to a smog station in socal on Friday and the tech said my timing was advanced to high so when he went to adjust it he jumped the larger yellow test plug (the one with 3 wires in the back) not the smaller one (the one with 2 wires in the back) and the engine died and now it will not start. He replaced the coil and cap and rotor. Now he is saying it is a different problem and it must have been pre existing! Does anyone have any idea what he could have done? Any help please. Sorry to thread on someone else's thread!
#34
ok!!!!!! update: I have put a new thermostat, check all the hoses, and took it for a cruise....I was driving on the road and ones the rpms come to 2500, it does the same thing, like that engine wants to die. I also found that this valve makes this loud clicking noise, as soon I take the small vacuum hose, it stop.
http://i966.photobucket.com/albums/a...0705-11501.jpg
#39
BINGO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I disconnect this sensor and rev up the engine to 2500 rpms, hold it for 90 seconds and no problem what so ever....I am reading on my manual and is telling me I have to test the ohm but I dont have one.... I guest I have to wait for payday to buy one.....THANK YOU WHORIDER for suggesting this....
#40
