just fail smog test in cali.........
Old 07-02-2010, 01:57 PM
norcal707's Avatar
hi everyone, I just got my 95 4runner back together from a hg replacement. I took it to do the smog check and fail because it wouldnt idle at 2500 rpm......it idles at 2500 for a second or so and then it goes down to 1000- 1500 rpm. also the radiator cap was leaking but I already replace it. if it idles higher than 2500 rpm it idles good. I dont know what to do, any suggestion please, thankyou
Old 07-02-2010, 01:58 PM
norcal707's Avatar
the 4runner is a v6 4wd 5 spd tranny
Old 07-02-2010, 04:08 PM
toyota4x4907's Avatar
Originally Posted by razed
huh? 2500 is about the highest idle the truck should ever idle at and then it would have to be about -20 outside for that.
regular idle shoud be about 800.
Eh, try -60. -20, mine is only about 1800 rpm
I dont think you have it right. It shouldnt be checked idling at 2500, it should be "under load" at 2500 rpm. Why would they check IDLE at 2500 rpm?
Is the timing spot on? Any CEL?
Old 07-02-2010, 04:10 PM
norcal707's Avatar
no, what I mean is when you push on the gas pedal and try to make the engine idle at 2500 rpm. it idle at 2500 for a few second and then the rpms gone down to 1000 or so rpm.
Old 07-02-2010, 04:12 PM
norcal707's Avatar
no CEL....the 4runner idles between 800 to 1100 rpm without pushing the gas pedal
Old 07-02-2010, 04:13 PM
norcal707's Avatar
the engine starts right away and it has the normal weak power...
Old 07-02-2010, 04:38 PM
yotaman85's Avatar
test station tech is an idiot and they are doing it so you fail and they get more money for retests. it is the tech job to press the pedal and get the engine speed to where its supposed to be and if they dont do that your truck will fail
file a complaint with the bureau of automotive repair
for sure. go to a differant test station.
Old 07-02-2010, 06:06 PM
toyospearo's Avatar
You live in Willits. Come up to Mckinlyville and go to Brians Smog. Super honest guy. Took my 82 to him with no problems.
Old 07-02-2010, 06:42 PM
Teuf's Avatar
It revs up to 2500 when you make it, it doesn't idle at that.
Old 07-02-2010, 08:51 PM
norcal707's Avatar
ok i am using the wrong words......the 4runner idles between 800 - 1100 rpms...when the mechanic revs up the engine to 2500 rpm and try to hold it do to the smog test, the engine would revs at 2500 rpm for a few seconds and then the rpms goes down to 1000 or so...do you guys understand? I might have to do a video....english is not my first language...
Old 07-02-2010, 10:27 PM
85gijunk4x4's Avatar
i was confused at first,but you just cleared it up for me.
his 4runner idles normal, but when the guy tried to raise the rpm to exicute the smog test, the 4runner would go to 2500 rpm, but it only stayed at 2500 rpm for a few seconds, so they failed him because they couldnt complete the test if his 4runner wasnt at 2500 rpm
Old 07-02-2010, 10:30 PM
1981 yota's Avatar
so happy i dont have to do smog tests
Old 07-03-2010, 09:12 AM
shell_meadows's Avatar
I too, live in NorCal and mind failed yesterday due to my timing being off by 5 degrees. It's too high, but besides that, he only tested mine at 1800 rpms. I think your smog guy is definitely duping you. but this is my opinion, means absolutely nothing. Hope you get it fixed.
Old 07-03-2010, 09:18 AM
norcal707's Avatar
exactly........I have check all the vacuum hoses, timing was little high and I am going to put a new thermostat. I am hoping this works but any suggestion would hurt to heard. thank you
Old 07-03-2010, 09:20 AM
CitrusTheDragon's Avatar
Am I the only guy on this site that has his CalBAR smog, brake and lamp? Sounds like the problem might be the tech but if you are losing it like that even when you press the pedal it can't be the tech. You can take it some where else but chances are you are going to fail again then be out that money. I suggest you run some of your own tests to see if its a misfire or compression lose somewhere. Sounds to me like a a lose of compression somewhere. That would also go with the head change. Keep us posted
Old 07-03-2010, 09:22 AM
norcal707's Avatar
I live in willits and you? see I took another car before there and no problem. I am thinking of taking it to a different one in a week or so and see what happend...
Old 07-03-2010, 09:27 AM
norcal707's Avatar
thanks man...I was thinking about taking it to a different shop....so can you tell me why do tech revs up the engine to 2500 rpms? my engine revs up fine pass the 2500 rpms. the problem is to hold it at 2500 rpms. I'll check all the vacuum hoses againg and see what happend
Old 07-03-2010, 09:48 AM
That's the rpm is where the optimal emission check is done. Basically its mid to start of the power band. It's where all the emissions control items should be working at peak. That's the easiest way to explain it, with out getting really in depth, and maybe losing you
Old 07-03-2010, 04:47 PM
norcal707's Avatar
ok here is a short video of my truck....as you can you, I am trying to rev up the engine to 2500 rpms and hold it for at least 45 sec but I cant...
http://www.youtube.com/watch?v=mF0btns1TMY
Old 07-03-2010, 05:30 PM
I'm stumped
Quick Reply: just fail smog test in cali.........
