Just blocked off my EGR....
Old 08-29-2010, 07:42 AM
  #221
chosenchange's Avatar
i just blocked mine off and got rid of the whole egr system on my 3.0. This is great it will make future spark plug changes very easy and it seems to be running smooth. Good move over all I think. I havnt passed emissions yet but if all else fails my buddies dad lives in castle rock and Ill register there.
Old 08-29-2010, 09:39 PM
  #222
well I used pbr cans for the exahust block where the pipe comes off the header that was a bad move!! two layers and it blew right through that. I now have stepped up the game and used a roofing tin shingle. much better I have noticed a huge difference in performance. Maybe not so much in acceleration but more in the fact when I go 70-75 i just kiss the 3g rpm rather then 3500 which I know will save me gas in the long run!!
Old 10-05-2010, 06:27 PM
  #223
benchernif's Avatar
Just did this at my dad's garage. I was reading code 72 and, after reading about this, I didn't feel like fixing the EGR if what you all claimed was true: performance increase and uses less fuel.
Used 1/4'' thick aluminium edging, a hacksaw and a machine drill. Only took about 2 hours to figure out the system, take out the EGR, and put in the new pieces. I've not put a resistor in yet, because I am still pulling codes 52 and 27, so I'll deal with it once I've finished those issues.
Thus far I've felt the engine works less hard, I have more power, and it starts easier.
Look at all that room in the engine now, too!
Thanks for the help, guys...
Ben
Old 10-05-2010, 06:40 PM
  #224
RustBucket's Avatar
Just did the blockoff on a 22re. I just pried the tube that lets the EGR gas into the intake manifold back 1/16" and stuffer in a piece of stainless steel with two holes drilled in it. Tightened it up -- no leaks, no problems. Truck was doing a weird idle thing, I believe the EGR would stick on at random times. Now that issue is gone. The way I see it, blocking it off isn't a big deal since it wasn't working properly anyway. That and the truck doesn't get alot of miles put on it...
Old 10-06-2010, 06:52 AM
  #225
tacho75's Avatar
same thing happen here...rustbucket...it was acting weird...so i unblocked the egr....
working better.i guess
Old 10-06-2010, 02:12 PM
  #226
Andy A's Avatar
Originally Posted by Xeo
Also I didnt have a EGR temp sensor in its place is what looks like to me to be a dud sensor plug with a resistor in it.
Does that little dud plug have a pt# on it by chance?????
Old 11-09-2011, 02:16 PM
  #227
JBANDIT57's Avatar
Ive removed both EGR valve and Reed Valve along with CAT delete (test pipe). Runs much better without any of it. just passed emmisions with flying colors last week. 92 4Runner 3vz-
Old 11-09-2011, 04:42 PM
  #228
Swansen's Avatar
i'm guessing Washington emissions? they must be pretty lenient.
Old 11-09-2011, 05:56 PM
  #229
JBANDIT57's Avatar
I guess lol. Atleast with OBDI vehicles. Ive had several problems with the same statioin with other vehicles so honestly i was surprised. Guess it all depends...
Old 11-09-2011, 06:19 PM
  #230
Swansen's Avatar
right on. i have limited experience with any form of emissions testing, but i guess that makes sense for the various generations of vehicles.
Old 08-01-2012, 10:16 PM
  #231
vehicular gaper's Avatar
getting ready to do this in the morning. is there anything else required other than just putting in the that plate to block off the EGR?
Old 08-20-2012, 09:58 AM
  #232
1991YotaDog's Avatar
Can I remove the EGR vacuum solenoid also? Plug those vacuum lines back on the plenum?
Old 08-21-2012, 12:29 AM
  #233
BirdDogg's Avatar
Instead of removing the egr and blocking it off, couldn't u simply remove the vac line that opens it?
Iceman4193
10-16-2015 10:50 AM
alexcarey
10-14-2015 06:05 PM
moparbay
10-06-2015 09:24 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
viesail
09-05-2015 04:23 AM
Quick Reply: Just blocked off my EGR....
