ITS alive! 3.0 afm mod!
Old 07-01-2008, 01:39 PM
swaycleveland's Avatar
3.o afm mod
Well after reading about a guy putting a 91 afm on a 3.0 I decided to try my luck!
So at this point I have 94 miles on the truck since the mod and will give the full blown details of what I did.
Went to the junk yard and found this beauty! Name:  IMAGE_00178.jpg
As you can see I took care to show the engine and vin for everyone wanting to use this mod! Name:  IMAGE_00173.jpg
Heres the old one and the new one!
I chose to keep the stock air filter. No real reason. Also im using duck tape to hold things together until I decide weather this will be a permant mod or not (which as of now it will be so I will be also doing the ISR mod
I had to do a bit of fine tuning to this afm . Not sure if it was this afm or the combo of new afm and old readings that dropped my idle however after moving 3 clicks COUNTER clockwise she ran like a top!!!!!!!!!!!!!!!!!!!!
After filling the tank and driving miles heres where the gas gage is! Now keep in mind im running a 3.0 AUTO with 4.88 gears and 285/75/16s with 38 psi which measure 32.8 if anyone cares
I will be updating this at the end of this tank and probly for the next month which should give a better fuel report.
Important !!!!!!!!!!!!!! Running 285s and 4.88 gears on an auto is well not the world’s fast combo however I can tell everyone this! wow this thing feels like its back on 31s or even 30s low end torque is way up and highway cruise Works I mean it takes hill with the cruise on without slamming down a gear I think its worth it just on the torque up grade even if the gas doesn’t show improvement alteast it didn’t go down!!!!! So ill keep you posted and feel free to ask questions in case I missed something!
File Type: jpg
swaycleveland is offline
Old 07-01-2008, 02:26 PM
Belize Off Road Team's Avatar
Right so, are you saying the intake hole is not 3inchs like on the 3.0? What do you mean you have ducktape all over it? how much bigger is it? any pics of it on your 3.0?
Belize Off Road Team is offline
Old 07-01-2008, 02:27 PM
JCM4x89pu's Avatar
awesome! so it was off a 1990 camry with the 2.5 liter v6? im curious to see how the gas milage turns out... if you can keep your foot off it!
JCM4x89pu is offline
Old 07-01-2008, 02:29 PM
the outlet end of the afm is bigger on the new one ! so the tube is now inside the hole instead of outside this is wear the ducktape is! just to make it air tight i think i have a pic hang tight!
Old 07-01-2008, 02:35 PM
K well i think i could get a 3"-?" intake tube
Old 07-01-2008, 02:38 PM
and just to be clear this is a 1990 v6 4cam afm!!!!!!!!!! heres the pic
Old 07-01-2008, 02:41 PM
whats with the duck tape in the front? does that not fit either? did the camry's not fit?
Old 07-01-2008, 02:42 PM
jcm 1/4 tank and im at 94 miles AND im under gear AND have an auto so this might be worst case senero!!! right size tires and gears and this could be a 3.4 in hiding hopefully someone with stock tires and gears will follow however i will be giving reports over this mth !
olharleyman's Avatar
Is it safe to belive you got 94 miles as shown on your tripometer after installing the camery v6 afm and 3 clicks counter clockwise??
Also what needs to be done to access the the clicker on the new afm?? and how does the power differ from the stock afm?
olharleyman is offline
Old 07-01-2008, 02:48 PM
belize as i stated before i just used the old air box the 1990 is square and should fit just fine this is just how i did it. as for the afm mod the is a thread on it and 4crawler.com explains it in great detail!
Old 07-01-2008, 02:51 PM
power seems good and like i stated before im running a 4.88 gear with 285 tires which means im MORE under powered then if it was stock
AFTER this mod i can say i feel BETTER then stock response and torque but time will tell the real story
Old 07-01-2008, 03:02 PM
galloway's Avatar
so i can do this on my 89 and it will prob. bring up the mpg ang low end
galloway is offline
Old 07-01-2008, 03:05 PM
i sure hope so ! thats why i am trying it on mine!
Old 07-01-2008, 03:07 PM
galloway's Avatar
sick i will have to try it on mine. but i will do it after i see how yours turn out lol
galloway is offline
Old 07-01-2008, 04:22 PM
bump for the night time crew!
Old 07-01-2008, 04:31 PM
yotasavg's Avatar
this looks like a good mod. i'm interested, be sure to post results.
yotasavg is offline
Old 07-01-2008, 04:51 PM
corax's Avatar
subscribed . . . now I just need to measure the AFM off my 7MGE to see how it measures up
corax is offline
Old 07-01-2008, 04:55 PM
corax i dont think it will work the reason i used the 1990 v6 camary afm is because the plug/pin/ work not to mention that different years worked differently i couldnt use a 93 3.0 from a camry afm because they send a different signal to the ecu
Old 07-01-2008, 05:05 PM
corax's Avatar
I'll just have to take some notes before my next junkyard run. My '88 7MGE AFM, IIRC, looked exactly the same as the 22RE, and the internals operate the same (variable resistance flapper door, vane airflow meter, internal fuel pump shut off switch, etc.) . . . . can you post up the order of wire colors from left to right looking at the top of the connector? I'll check mine tomorrow when I get back from NM
corax is offline
Old 07-01-2008, 05:09 PM
i can do you one better ! i have the cover off the afm so you can see the guts ! and yes i will give you the colors and pins also
Quick Reply: ITS alive! 3.0 afm mod!
